| | | Forums66 Topics128,078 Posts1,055,939 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2017 Posts: 308 'Bolter | | 'Bolter Joined: Jan 2017 Posts: 308 | How could one determine HP, with a rebuilt engine bored over .40, Fenton Headers, 848 rebuilt head with new rocker arms and shafts. Weber 32/36 carb with heat from Radiator. Need anything else--Thanks Bill | | | | | Joined: Feb 2004 Posts: 29,780 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,780 | Just do what everybody else does- - - - -lie about it! To get an accurate reading, you'll need a dyno.
Horsepower = torque X RPM divided by 5250. Then you'll need to dial in a correction for ambient temperature and humidity. On average, the correction factor reduces the raw HP figure by 5 to 7 percent. There's a computer simulation program called "Desktop Dyno" that seems to be pretty accurate. I've done a few fantasy engine builds with D/D on small block Chevy engines, using the same parts specifications as ones I've actually built and dyno'ed, and the numbers came out close to equal for the real thing and the computer simulation. Jerry
