| | | Forums66 Topics128,132 Posts1,056,376 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2005 Posts: 1,624 Shop Shark | | Shop Shark Joined: May 2005 Posts: 1,624 | As we upgrade, modify and change electrical components on our rides to make them both more safe and improve our chances of getting where we plan to go, I keep running into a problem. The FLAPS and manufactures do not provide the information necessary to change components. My main complaint right now is sensors. Changing from a bulb type temperature or oil pressure gauge to a variable resistance type is hit and miss, mostly miss. I’ve looked all over the internet for specifications and can’t find anything other that what cars they fit. Through a process of calibration I know the resistance profiles I’m looking for, but can’t fine the data for the sensors. I often read questions on this forum about gas gauges with wrong sending units and other sensor issues. Where do you guys go to get information on sensors? Engineers who design engines must get that information from somewhere.
| | | | | Joined: May 2015 Posts: 11,074 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,074 | I've used a pot of water on a stove, thermometer and multimeter to figure out the resistance for a temperature sensor. A pressure sensor would be a bit more trouble. And you'd have to buy the sensor to find out whether it would work or not.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: May 2005 Posts: 1,624 Shop Shark | | Shop Shark Joined: May 2005 Posts: 1,624 | My point exactly. I have a pressure manifold setup I can use. Also can do the hot water thing. Vacuum in is not in my tool kit. The problem is, I go see the kid at the FLAPS. Flip a coin and buy a ‘x’ type sensor. Go to the shop and test. It doesn’t have the correct resistance profile, so take it back. Flip another coin,and so on.
| | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy beltfed and guys, on the older GM stuff like the water temperature senders used the same ohms range as the fuel tank senders 0-30 ohms, one tester could test the fuel gauge sender and the water temperature sender. Oil pressure senders were a bit trickier you had to know the maximum reading of the gauge in p.s.i. as one of the criteria for ordering the correct sender. As usual all the manufacturers used different ohms ranges for their oil gauges and senders and the aftermarket used their own as well Stewart-Warner used their own ohms range as well. So you had to use the correct sender for the gauge you wanted to use, not so hard to do when our trucks were relatively new, but now half a century later senders for our original gauges are no longer in stock unless 54 3600 could possibly find n.o.s. ones if we furnished him the part numbers. Classic Instruments website has some ohms ranges for the different fuel gauge senders they sell, have a look and you'll see what I mean about everyone being different, hope that helps. | | | | | Joined: May 2005 Posts: 1,624 Shop Shark | | Shop Shark Joined: May 2005 Posts: 1,624 | Thanks 3B. Testing and finding the resistance profile or ohms vs whatever is not the problem for most gauges. Unless you go way back and get something like a “King-Seely” type. If one finds a gauge that suits the purpose and function then you have to provide it with the correct input to be of any use. Using off the shelf is, IMO, not the old school way of doing it. I’m going to reach out to John Wolf. His company rebuilt all the gauges for the Lindbergh’s Spirit of St. Louis. If he can tell me anything, I will pass it on here. Thanks
| | | | | Joined: May 2005 Posts: 1,624 Shop Shark | | Shop Shark Joined: May 2005 Posts: 1,624 | I called and spoke to Mr. John Wolf. He said that a company called “Airtex Wells” has a good site for information on oil pressure senders. I have search a bit and have yet to find the site where this data is stored. One of you computer jocks might have more luck. If anyone does find it please post as I think it will help someone (that would be me).
| | | | | Joined: Jul 2000 Posts: 2,195 Insomniac | | Insomniac Joined: Jul 2000 Posts: 2,195 | Maybe this is what you are looking for? Sender data
Gord 🇨🇦 ---- 1954 1/2 ton 235 4 speed | | | | | Joined: May 2005 Posts: 1,624 Shop Shark | | Shop Shark Joined: May 2005 Posts: 1,624 | Thanks much for finding the correct site Gord. This will help me and hopefully others in our effort to get gauges to read correctly. This data will be printed and put in my hard copy data file.
