3 members (tclederman, Bill Hanlon, 1 invisible), 197 guests, and 3 robots.
Topics128,106
Posts1,056,213
Members48,436
#1279358 09/06/2018 7:19 PM
Hi all ... I have a 1954 chevy 3100 and need to get new tires on the truck to be able to move it since the tires are shot. I have 16" rims but I'm not sure they are original. 3 of them look like they may be (paint colors match) but one has a totally different paint color. I read a post about tire recommendations on this forum and am planning to get 235/85/16 LT E rated. But before I do I thought I'd pass it by you because I know zip about tires.
Right now the tires on the truck are on the back Michelin 205/80 R16 104T M+S Radial XM.
The front tires are Armstrong 6.50-16 LT SD 200.
Any idea if the tires I'm planning to get would fit?
Thanks so much!!
1954 Chevy 3100
1994 Nissan 300ZX Convertible
You didn’t state if the tires are just to “Move it” or drive it. Two entirely different things. If your just moving it around then air up what you have or get some six lug wheels/tires from your local salvage that will hold air. If it’s time to start driving then what you have proposed buying will be just fine.🛠
I'm about to the point where I need to get tires too.. Will regular tubeless work on these old steel wheels? I guess I'm wondering if they are air tight
1953 3100 Mariner blue (some anyway)
Thank you for your reply Martin. The current tires won't hold air, so I'm just going to put new ones on at this point.
1954 Chevy 3100
235/85/16 LT E rated tires are the standard size for a '99-'04 Ford Superduty F250 or F350. They are way oversize for a '54 3100 and require a wheel that's 7 inches wide. The standard wheels for a 3100 are 4 or 4.5 inches wide.
I believe that some of the guys here have recommended 215/85R16. C load rated tires would be plenty for what you need. Higher load rated tires would give you a much stiffer ride, bordering on tooth-rattling.
ODSS President
ODSS President
Yes, indeed. I have logged on 110,000 miles with 215 85R 16 Michelin Radial X tires. No tubes, stock rims. The first set I bought 'gently used second hand' and got nearly 50k miles and at the end the tread on all four was still legal. Second set, same model and size, same mileage. I am now on a third set. Good luck with your decision.
~ Cosmo
1949 Chevy Half Ton
ditto on using 215 85R 16 (radial)
Play with the PSI to achieve best tracking (lower pressure) and easy steering (higher pressure).
Leo Offline
Moderator
Moderator
I had the 215 85R 16s as well. Mine wouldn't hold air overnight unless I had tubes. Ran tubes for years, no problems.
V
V Offline
Ditto on 215 85R 16's
I have had tubes in the set on my Suburban for about 15 years.
The rims on my pickup did not require tubes.
