7 members (Jon G, fonz8261, MickeyP, Otto Skorzeny, 2-Ton, TexasJim50, 1 invisible),
90
Mod | | | Forums66 Topics128,132 Posts1,056,383 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2010 Posts: 118 'Bolter | | 'Bolter Joined: Mar 2010 Posts: 118 | Howdy, so I am in the process of doing some patching on both of my front fenders on my '57 half ton. Looking at the front fender extensions that rivet to the fender there are staples punched through the fender extension as if there should be a seal there between the ext and the front of the fender. There wasn't one there when I tore everything apart a couple years ago. Should there be a seal there and if so what seal is it? I don't see anything on any of the usual parts sites for this area. Pics of the area: Extension1 Backside Extension2 | | | | | Joined: May 2017 Posts: 100 'Bolter | | 'Bolter Joined: May 2017 Posts: 100 | You can look and look no supplier has this item .But if you look at your inner fender the back seal that is stapled on is the same as the piece you are looking for, fits perfect. Hard to staple in ,I used weather strip glue and a few small rivets to hold in place.Just buy the rubber for inner fenders and cut to fit . It is easy to install if you take the rivets out, put rubber on and then reinstall ,with some round headed blind rivets
!956 Gmc Napco 4x4 Factory line built .
| | | | | Joined: Mar 2010 Posts: 118 'Bolter | | 'Bolter Joined: Mar 2010 Posts: 118 | Alright, I had a thought that might be the same type of seal. Also makes sense that the extension is riveted on now with having a seal there. | | |
