| | | Forums66 Topics128,212 Posts1,057,468 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2018 Posts: 46 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2018 Posts: 46 | My family and I are looking at buying my father a 51 dually dum / stake bed for his 70th birthday. From what I understand they are different enough from their little brothers that I could use some guidance in avoiding any potential pitfalls with difficult to find or replace pars such as brake parts.
Any guidance would be appreciated.
1950 GMC 1/2 Ton Long Box 228-Zenith carb- SM420-bendix brakes
| | | | | Joined: Feb 2004 Posts: 29,889 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,889 | Rear brake drums are about as scarce as unicorns or honest politicians. The 18" tube type tires they came with originally are E$$PENSIVE also, so one with good brakes and tires will command a high price from anyone who knows what those parts are worth. You can justify making a lowball offer if it needs either brake work or tires! If you happen to luck into one with 19.5" tubeless tires and wheels, it's definitely a keeper! Jerry
| | | | | Joined: Nov 1995 Posts: 5,747 24601 | | 24601 Joined: Nov 1995 Posts: 5,747 | Drtheo,
Just chiming in until the other experts get here so you aren't left hanging There are a few folks on here (like Amtrak Joe) who are actively restoring 3800 duallies and can talk authoritatively about peculiarities and the most expensive/hard to find parts.
~ John A kid raised on Hotwheels, Matchbox and Tonka cannot be reasonably expected to own only one vehicle as an adult. 1949 Chevrolet 3804In the Legacy Gallery | In the Gallery Forum1973 IH 1310 Dump1963 Kaiser M38A12001 International/AmTran RE3000 "Skoolie"2014 Ford E-350 4x4 (Quigley) | | | | | Joined: Nov 2012 Posts: 444 Stovebolt Photo Moderator | | Stovebolt Photo Moderator Joined: Nov 2012 Posts: 444 | Drtheo,
I do have a pair of 1-ton dually's, 1947 AD
Jerry about sums up the complexity of tires, rims and brakes. The rear brake shoes are not available. One must have them re-lined. The drums are scarce. The spring between the shoes on the bottom is available from Carters. The retention hardware clips are scarce but you could use snap rings instead but you will have to hunt around. Master Cylinders are larger bore but available. Rear differential swaps out to a more drivable 4:10 vs. the 5:14 stock. Not much else to say. Most hardware is available, kingpins are out there too. The rest of the truck is similar to a 3100 or 3800. They are easier to work on, one could slide right under and change the oil and snoop around.
Leaf springs are not available through the typical vendors and you need to check the front lower leafs to make sure the bolt hole is not egged out. She will wander if it is. There are companies out there to bend new lower leafs if you find it worn.
I say buy it.
Joe 1947 - 3800 dually known as "Deadwrench"Link to a few photosIn this world there are givers and takers. The takers eat well, the givers sleep well. | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | | | | | | Joined: Dec 2007 Posts: 171 Shop Shark | | Shop Shark Joined: Dec 2007 Posts: 171 | Drtheo, you and I are in the same boat. I have been asked, by a motivated seller to come and look at a 1949 3800 dually, (with a mostly intact Williamson stock rack). Doesn't run and hasn't for many many years. This truck is the 5 window model with those windows intact. It does have a full set of matching and proper 18" wheels, OLD tires. Al | | |
