6 members (Charles in CA, lumbersawyer, Rustnut, Hotrod Lincoln, Donf, 1 invisible), 64 guests, and 4 robots.
Topics128,203
Posts1,057,414
Members48,471
My family and I are looking at buying my father a 51 dually dum / stake bed for his 70th birthday.
From what I understand they are different enough from their little brothers that I could use some guidance in avoiding any potential pitfalls with difficult to find or replace pars such as brake parts.
Any guidance would be appreciated.
1950 GMC 1/2 Ton Long Box
228-Zenith carb- SM420-bendix brakes
H Online: Content
Rear brake drums are about as scarce as unicorns or honest politicians. The 18" tube type tires they came with originally are E$$PENSIVE also, so one with good brakes and tires will command a high price from anyone who knows what those parts are worth. You can justify making a lowball offer if it needs either brake work or tires! If you happen to luck into one with 19.5" tubeless tires and wheels, it's definitely a keeper!
24601
24601
Drtheo,
Just chiming in until the other experts get here so you aren't left hanging There are a few folks on here (like Amtrak Joe) who are actively restoring 3800 duallies and can talk authoritatively about peculiarities and the most expensive/hard to find parts.
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
2014 Ford E-350 4x4 (Quigley)
Stovebolt Photo Moderator
Drtheo,
I do have a pair of 1-ton dually's, 1947 AD
Jerry about sums up the complexity of tires, rims and brakes. The rear brake shoes are not available. One must have them re-lined. The drums are scarce. The spring between the shoes on the bottom is available from Carters. The retention hardware clips are scarce but you could use snap rings instead but you will have to hunt around. Master Cylinders are larger bore but available. Rear differential swaps out to a more drivable 4:10 vs. the 5:14 stock. Not much else to say. Most hardware is available, kingpins are out there too. The rest of the truck is similar to a 3100 or 3800. They are easier to work on, one could slide right under and change the oil and snoop around.
Leaf springs are not available through the typical vendors and you need to check the front lower leafs to make sure the bolt hole is not egged out. She will wander if it is. There are companies out there to bend new lower leafs if you find it worn.
I say buy it.
Joe
1947 - 3800 dually known as "Deadwrench"
Link to a few photos
In this world there are givers and takers. The takers eat well, the givers sleep well.
Drtheo, you and I are in the same boat. I have been asked, by a motivated seller to come and look at a 1949 3800 dually, (with a mostly intact Williamson stock rack). Doesn't run and hasn't for many many years. This truck is the 5 window model with those windows intact. It does have a full set of matching and proper 18" wheels, OLD tires.
Al
smile Alan
1947 (early) GMC EC-302 Dump Truck
Jimmy
More pix in Photobucket
Moderated by  Dusty53
