| | | Forums66 Topics128,014 Posts1,055,328 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | Sometimes if it sits for more than two or three days the float bowl is empty and I have to crank the starter for a while to get gas back to the carburetor. Sometimes it can sit for a week or more and start right up. I replaced the fuel pump which helped but didn't completely fix the issue. What do I need to look at? It's on a 53 235 with Powerglide. To the best of my knowledge it's the original carburetor.
| | | | | Joined: Mar 2010 Posts: 10,270 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,270 | I am curious if the bowl ever gets full when the engine is running. Maybe your fuel pump is weak. 2-3 days is a short time for the entire bowl to evaporate out.
| | | | | Joined: Nov 2002 Posts: 2,763 Carburetion specialist | | Carburetion specialist Joined: Nov 2002 Posts: 2,763 | Good carburetion is fuelish hot airThe most expensive carburetor is the wrong one you attempt to modify. If you truly believe "one size fits all," try walking a mile in your spouse's shoes!The Carburetor Shop | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | I am curious if the bowl ever gets full when the engine is running. Maybe your fuel pump is weak. 2-3 days is a short time for the entire bowl to evaporate out. "I replaced the fuel pump which helped but didn't completely fix the issue."  Useful info there Jon.
