| | | Forums66 Topics128,018 Posts1,055,342 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2015 Posts: 201 Shop Shark | | Shop Shark Joined: Jun 2015 Posts: 201 | So having trouble with my 41, it’s got a 235 with a 216 type bell housing and 4 speed transmission. Today I was driving and I all the sudden couldn’t get it to come outta gear even while the clutch was in or anything so got it the emergency lane and managed to get in neutral and then it wouldn’t go in any gear.
After that I turned off and with the truck off and it went into all the gears fine with the truck off so put it in forth and drove it home in forth the whole way. Shut it off put it in first to pull it in and started it and pushed the clutch and the clutch didn’t disengage it it wanted to keep going.
Clutch adjustment is already as back as it can go, it’s been fine all year and haven’t changed anything... anyone know what’s going on? | | | | | Joined: Mar 2014 Posts: 4,477 Moderator, Electrical Bay | | Moderator, Electrical Bay Joined: Mar 2014 Posts: 4,477 | Could be your pressure plate has broken. It isn't uncommon. With the truck not running, get underneath and remove the clutch cover. Have your wife or somebody press in on the clutch while you look up in there with good light. You should see the pressure plate move rearward evenly and separate cleanly from your clutch disk. If you use a screwdriver, you should be able to move the clutch disk at that point. You probably will have to use a remote starter (ignition off) to turn the engine over (put it in neutral) to see the whole circle. If your pressure plate has broken, some part of the circle will not release and I believe this is what is causing your problem.
~ Jon 1952 1/2 ton with 1959 235 | T5 with 3.07 rear end
| | | | | Joined: Mar 2014 Posts: 4,477 Moderator, Electrical Bay | | Moderator, Electrical Bay Joined: Mar 2014 Posts: 4,477 | Once you have the pressure plate out, lay it on a table and if you see some of the fingers sitting lower than the others, you know that pressure plate is gone.
