1 members (stoveboltgator), 218 guests, and 0 robots.
Topics128,048
Posts1,055,540
Members48,425
#1278701 09/01/2018 1:53 PM
I have a ‘47 AD 3100 that I believe the PO retrofit a later box to the chassis. I did body work on the right side and added a new angle strip. The left side I simply ordered a new side from Mar-k. The new side fit perfectly.
The issue I’m having is getting the box to measure to specs. The last sill is welded to the original right side. Is the correct procedure simply loosening all bolts and shifting/adjusting the panels so the correct measurements are met? Another words I should just “play” with panels to get it right? Or is there some other point I’m missing?
Insomniac
Insomniac
Measure to specs? In my case, I knew the sides were the same length and the distance between them at the front and rear was equal. All I had left to do was check the diagonal measurements; a bit of pushing corrected that and we were done.
Gord 🇨🇦
1954 1/2 ton 235 4 speed
