7 members (rfs56trk, Gray_Ghost, Wally / Montana, walter74, MRMEROTH11, David Bush, 1 invisible),
67
Mod | | | Forums66 Topics128,056 Posts1,055,803 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2008 Posts: 261 'Bolter | | 'Bolter Joined: Nov 2008 Posts: 261 | Hi All,
I have a 1/2 1950 chevy truck. I purchase fender welting from one of the vendors, cannot remember which one. I realize I have to cut out pie shaped notches to get it to contour the fender shape. I am trying to install the from fenders but welting material does not seem wide enough. I is not wide enough to use the mounting holes on the fender or on the cab sheetmetal. I this correct? I always thought the mounting screws would pass through the welting material to help keep it in place. May be I am not understanding how to install it. I have done a search but did not see anything on the front fender installation.
thanks, skipper | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | How wide is the welting (outward from the "cord")?
Can you attach a picture (with a ruler next to it)?
What vender and part number? If it is listed/shown on-line, post a link to it. | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | The replacement welting is not as wide as original You will have to pie cut it and cut out holes ...pic... | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | | | | | | Joined: Mar 2010 Posts: 10,274 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,274 | I notch them with pie cuts and cut off the ends of the pie pieces which interfered with the bolt holes. I then use all seven of my hands to hold the welting in place while tightening the fender bolts. (I use my other two extra long arms which have the extra reverse bend elbows for tightening those bolts.) Can you smell "Tech Tip" nominee? Carl
| | | | | Joined: Apr 2016 Posts: 1,042 'Bolter | | 'Bolter Joined: Apr 2016 Posts: 1,042 | I would like to see a video of that Carl.
| | | | | Joined: Nov 2008 Posts: 261 'Bolter | | 'Bolter Joined: Nov 2008 Posts: 261 | I measured my welting, the edge is 1.25" from the tubing edge. I believe I purchased it from Classic Truck. Dads50, I see from you picture that the front welting, the fender mounting holes do not go through the welting. Did you use adhesive to keep it from sliding around? | | | | | Joined: May 2004 Posts: 1,312 'Bolter | | 'Bolter Joined: May 2004 Posts: 1,312 | I used a little bit of weatherstrip adhesive to affix the welting correctly on the flange of the fender. Pie cut the welting to curve, and to miss bolt holes. Once adhesive is dry, easy install.
| | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | I just used the tape seen in the pic, once the bolts we in I fished it out.
small amount of adhesive sounds like a good Idea
I just wanted it kinda loose so I could readjust as needed | | | | | Joined: Jul 2014 Posts: 1,289 Moderator for Tons o' Fun , Co-Moderator Driveline Forum | | Moderator for Tons o' Fun , Co-Moderator Driveline Forum Joined: Jul 2014 Posts: 1,289 | Skipper thanks for starting this good conversation , Based on your experience, Dads50, 52Carl, and Britcon, do you think these ones from Chevs of the 40's would work without modification? https://www.chevsofthe40s.com/dept/Fender/cat/Gaskets.htmlsee 609725 part number on the page
Ron - - Dusty53 1954 Chevy 3604In the Gallery Forum "You can't dance with the Devil and then wonder why you're still in Hell." "They will forget what you've said, and they will forget what you have done but they will never forget the way you made them feel." | | | | | Joined: Jul 2008 Posts: 1,321 'Bolter | | 'Bolter Joined: Jul 2008 Posts: 1,321 | Ronnie, Jim Carter sells the same ITEM for half the price. I used these on my truck and they worked great. This is for the inner fender.Harold NOTE The item in my post is in reply to Ronnie asking about The gasket set for the inner panel with lower rear mount pads.https://www.chevsofthe40s.com/dept/Fender/cat/Gaskets.html
Harold Is a restoration ever finished? | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | Both of those seem to be missing the distinctive bead
But its had to tell from the pic | | | | | Joined: Jan 2016 Posts: 1,101 'Bolter | | 'Bolter Joined: Jan 2016 Posts: 1,101 | I didn't worry about the fender bolts going through the welting when I installed it on my fenders. I just relied on the pinch pressure of the fenders to hold the welting in place. I have not had any issues. It has been in place for about 2 years. | | |
