2 members (mo2cyl, panic),
59
Mod | | | Forums66 Topics128,009 Posts1,055,293 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#12785 06/03/2004 11:58 AM | Joined: Jan 2000 Posts: 1,586 Extreme Gabster | | Extreme Gabster Joined: Jan 2000 Posts: 1,586 | I bought this scale at a police auction for a few bucks, the previous owner is serving a little time away from home,lol. These British Royal Enfield bike parts are quite consistant, only a a few tenths of a gram difference, but on my Stovebolts, the pistons and rods were many grams difference in weight.The crankshafts on inline engines are balanced seperately from the rods and pistons etc,and the local machine shop said the factory balancing on cranks is almost always good, it's the other parts that need balancing.Rods should be done one end at a time on a axle so the rod pivots and you trim the small or big end accordingly.Anyways it fun to do when you're bored, notice the bike crank in the photo, an inline engine [img] http://img.villagephotos.com/p/2003-1/95040/LLLVH-scale.jpg[/img] | | |
#12786 06/03/2004 2:10 PM | Joined: Jun 2001 Posts: 379 Shop Shark | | Shop Shark Joined: Jun 2001 Posts: 379 | Tony, do the police enter auction buyers into their database for future followups? I wondered about that when I saw all the high pressure sodium light setups they were auctioning off here.  | | |
#12787 06/03/2004 2:42 PM | Joined: Jan 2000 Posts: 1,586 Extreme Gabster | | Extreme Gabster Joined: Jan 2000 Posts: 1,586 | I don't know, just paid the money and left.I told them I was gonna weight motor cycle parts,they said "yeah right" and laughed. | | |
#12788 06/03/2004 3:38 PM | | Anonymous Unregistered | | Anonymous Unregistered | Tony, When doing final balancing of rods, pistons, wrist pin assys . . . the machine shop that I worked with took an end-mill that was just slightly larger than the wrist pin bore and went in on the ends of the pins to get the weights all within .1 grams for the assembled components.
The pistons were already within .1 grams of each other, but the rods varied a little (+/-0.5 grams) and there were no good places to machine that much material off - | | |
#12789 06/03/2004 5:16 PM | Joined: Jan 2000 Posts: 1,586 Extreme Gabster | | Extreme Gabster Joined: Jan 2000 Posts: 1,586 | When I did one of my 261 engines,the rods were off on the top end,so I made adjustments by taking the lightest rod on the small end ,and put the heaviest piston on that rod.The engine is very smooth, so I must have done something right. British bikes all have forged aluminum rods, the big ends have a web on the cap you can grind on, but they are usually very close in weight.On the pistons I remove material on the wrist pin side. | | |
#12790 06/03/2004 7:35 PM | Joined: Feb 2004 Posts: 29,742 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,742 | Tony, I use the exact same triple-beam scale in the school shop, weight-matching rods, pistons, etc., prior to spin-balancing smallblock Chevy crankshafts. We match them to +/- 1/10 gram. Since a dollar bill weighs almost exactly a gram, that's pretty close! I've also got an old 2-pan beam-balance scale my father used to use on flathead Furd parts back in the late 40's, and it still works. I just have to find the lightest part with that one, and use it as a reference while I match the other pieces to it.
BTW, some of the race wrist pins I use come with instructions NOT to try to balance by machining the pin ends. If the pin is running against a lock ring in the piston boss, machining the hardened end surface away might result in premature wear. Be careful! Jerry
#12791 06/03/2004 7:45 PM | Joined: May 2003 Posts: 1,271 Shop Shark | | Shop Shark Joined: May 2003 Posts: 1,271 |
~~ Alan Horvath 1954 Chevy PickupSinging his praises in thePassing Lane | | |
#12792 06/04/2004 12:43 AM | Joined: Jan 2000 Posts: 1,586 Extreme Gabster | | Extreme Gabster Joined: Jan 2000 Posts: 1,586 | Ha, isn't Indica the smoke of choice today? Jerry, I used to balance the bike cranks on a set of parallel knife edges.The cranks were balanced with a factor of the total rod and piston weight,between 70-85 percent depending on the rpm range you run it. British 40-45 cubic inch twin cycle engines always vibrate,the trick is to put the vibration at a speed where you don't usually ride at.Vibration can be so bad it blurs your vision,now that can't be good. | | |
