0 members (), 149 guests, and 2 robots.
Topics128,113
Posts1,056,619
Members48,450
#1278250 08/29/2018 4:20 AM
Hi All,ive got a 52 chevrolet 6400 truck.I have renewed all the brake cylinders front and back the master cylinder is new the hydrovac to is good,I am having trouble getting a stiff pedal. I have bled as the manual says. If i clamp off the rear flexi pipeiget a stiff pedal so I am guessing the problem is at the rear.I have adjusted the shoes and bled the cylinders but still no pedal.Although there are two brake cylinders per wheel station only one of the cylinders has a bleed nipple could there be trapped air if so how can i fix the problem. many thanks for reading. Howard
"52 chevrolet 6400 truck." - 2 ton
"I have bled as the manual says."
Pressure Bleeding
Did you use a pressure bleeder?
Did you bleed in the described order - wheel order, and cylinder order, and then, hydrovac?
3B Offline
Hy Howardwade, this may sound like a silly question but, on your rear brake cylinders are the bleed screws in the uppermost port of the upper wheel cylinder?
Crusing in the Passing Lane
Seem like my book says hydrovac first?
Ed
What year/make/size truck is your book for, Ed
1954 Chevrolet says bleed the hydrovac first - the earlier book that I linked-to above states differently. I think the system in question in this post is 1952 (the manual that I linked-to earlier).
Actually, there is a 1952 "addenda" to that manual: I'll try to remember to check it out tomorrow.
Big Bolt Forum Moderator
on my 55.2 and my 58, one of the rear brake shoes has to be adjusted all the way loose (collapses the wheel cylinder) when bleeding, then you adjust the brakes.... yours may be the same? Double check the procedure in the manual.
Mike
Hello chaps. I have bled as the manual says. Hydrovac first then cylinders.
There is an online 1951 1.5 and 2 Ton Brake Service Manual that has helpful pictures.
But that method uses a pressure bleeder tank tool.
http://chevy.oldcarmanualproject.com/booklets/51mts06/5106mtsindex.html
Same equipment & procedure as shown in 48-51 Shop Manual in a post above.
There are more and better pictures at your link, though, Soggy - Thanks
Still having trouble ijust cannot get a pedal. i have bled and bled the system. I have clamped the year flexi andyou can get a pedal. Sothe fault is at the rear end.
Does your Hydrovac work?
Are you pressure bleeding the system?
Do you get a hard pedal when you clamp both fronts?
Have you ever had the brakes "work good"?
What's new in the system (MC, Wheel Cylinders, Hydrovac etc.)?
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
