5 members (gswbbc, Otto Skorzeny, Eisenholtz, klhansen, 1 invisible), 82 guests, and 2 robots.
Topics128,032
Posts1,055,521
Members48,425
#127824 08/24/2007 4:17 AM
Hello, What are you guys using for tack rags?
Jesus is Lord!
Only through the blood of Jesus are you washed clean of your sins.
Come see us... Dad's Chevy
Our Video
God bless you! Michael..
#127825 08/24/2007 5:45 AM
tack rags is what I use for tack rags, when doing wood work ... available at any general paint store
for auto body work, I blow off the surface with the air gun, then use a good grease/wax remover, before sanding and before priming or painting
#127826 08/24/2007 1:18 PM
on the issues of grease/wax remover, does acetone make a good one?
1960 GMC 305A V-6 Gallery Page
Remember, the government cannot give --anything to anyone --that they have not first taken away from someone else.
BUY AMERICAN http://www.stillmadeinusa.com/index.html
#127827 08/24/2007 2:22 PM
I was wondering if anyone had any sort of special way of making their own and how that is?
Jesus is Lord!
Our Video
#127828 08/24/2007 2:59 PM
Ex Hall Monitor
Ex Hall Monitor
Quote
NO! Much too caustic. Plain old mineral spirits works OK. Whatever you use make sure to wipe it off before it dries.
#127829 08/24/2007 3:18 PM
and wipe in one direction only Jake, don't rub the dirt back in!!
Michael - tacks are usually a mix of thinner and varnish I believe, on cheesecloth, but they're so cheap, why bother?
#127830 08/24/2007 4:47 PM
I would think Acetone would peel your primer right off ..good blowin off of parts an a good clean with mineral spirits would be best ..or a Wax & Grease remover from your local FLAPS
1952 Chevy Shortbed
Photos in Photobucket
#127831 08/24/2007 5:02 PM
On the acetone I was using it on the bare metal as a cleaning prior to priming, Would that be OK?
#127832 08/24/2007 5:54 PM
V-6 ,
on bare metal ACETONE it is a great cleaner ..
it avoporates in seconds ..an works great ..but for final prep a grease an wax remover is always a good choice before ya tack it down an shoot primer or color ..just remeber CLEAN is 100% of any paint job
1952 Chevy Shortbed
#127833 08/24/2007 6:45 PM
Apprentice
Apprentice
Dear Michael;
Laquer thinner is okay prior to priming and already there (in stock).
Wax/grease remover is for painted/primed surfaces (as stated) prior to sanding etc.
Then a 'tach rag' is used, just prior to 'shooting' etc.
You can get them from the automotive Paint Store.
Good luck. smile
"There are no shortcuts to any place worth going"; Anon....
#127834 08/25/2007 12:21 AM
Ex Hall Monitor
Ex Hall Monitor
Quote
It dries too quick. The key is to keep it wet until you wipe it off. If it dries before you get it wiped off the wax is still on the metal. In no way shape or form is acetone good for pre-paint wax & grease removal.
FYI, back in the day when dirt was young & I earned my living with a paint gun, tack rags were cheese cloth impregnated with bees wax. Can't say what's in them these days.
#127835 08/25/2007 3:03 AM
Tiny, the ones I use (I get them at the local farm store in the paint dept.) are just that, cheesecloth with beeswax. Super cheap. I got a box of 25 for under $5.
Bill Burmeister
#127836 08/25/2007 4:06 AM
if they used beeswax on tack cloths you couldn't get'em cheap!! and beeswax isn't 'tacky', makes a good releaser to keep drill bits from sticking in aluminum, it's a ..... wax
the sticky on commercial tack cloths is rosin [resin], which I think they dissolve in alcohol to apply, then the alcohol evaporates
#127837 08/25/2007 5:57 AM
Commercial Tack rags usually work better if left out to dry over night.
But when it comes to grease and wax remover I prefer DuPont Final Klean 3901S™ it is a fast-dry surface cleaner formulated to speed final surface preparation prior to painting. DuPont Final Klean 3901S™ works well in removing sanding sludge, dust, fingerprints, and small amounts of grease and oil.
It dries slower than lacquer thinner but fast than mineral spirits.
generally, when you are sanding a finish either scuffing it, or actually sanding the old paint off, you are removing any wax or grease in the process. Where you have to be careful is just before you apply any coating. Greasy finger prints, are the major problem. So before you apply any coating whether it be primer or paint, you need to get rid of the finger prints.
Frank
No better smell than that of fresh paint. I've been building and painting cars/trucks for 47 years. Not gonna stop now.
http://www.coxcustomcars.com/
#127838 08/25/2007 7:27 PM
Ex Hall Monitor
Ex Hall Monitor
Quote
It's not as bad as it sounds Bill. As I said I don't know if they still use beeswax but look at it this way. What is in wax that makes paint fisheye? Silicone. What is "fisheye eliminator" that you put in paint when you get fisheyes so that the paint will stick to them? Silicone (at least used to be back in the day). When used correctly and in proper amounts, materials that would normally be taboo can be benificial. Look at chlorene in drinking water, botulin (sp?) toxin to get rid of wrinkes, phosphoric acid in soft drinks, etc..
The proper way to use a tack rag is to completely unfold it and kneed it several times to warm it up and increase the tack. You then lightly wad it up and LIGHTLY rub the surface to be painted, refolding it as necessary. It wouldn't surprise me if they're using resin these days, it's probably cheaper and may do a better job.
#127839 08/26/2007 6:26 AM
Thanks for the info all... I was not aware they made such a thing for the auto body. When I was in high school (long ago) I was told to make one with wet paint on it so that you ended up with a sticky rag. I was not sure how that stacked up.
Jesus is Lord!
Our Video
#127840 09/08/2007 5:43 AM
it is a bad idea to sand greese off if a panel is really dirty i always clean it really good firstbefor i even do body work sanding just moves it around and pushes it into the paint fisheye city
#127841 09/08/2007 5:50 PM
Maybe I am not correctly understanding some of the posts above, but, I do not think it would be good idea to use any silicone-based (or silicone-impregnated) product anywhere near a surface that was being prepared to be painted.
#127842 09/09/2007 2:51 PM
Ex Hall Monitor
Ex Hall Monitor
Quote
You're right. Thanks for pointing out that I didn't make myself clear. I wasn't refering to silicone being in bees wax. I don't know if bees wax has silicone in it or not. I was refering to auto polishes and waxes. However the fix for fisheyes was (still is???) silicone (fisheye eliminator) added to the paint. It is far better to clean the surface to be painted than to use fisheye eliminator since it leaves a somewhat orangepeal finish when it is used.
#127843 09/09/2007 4:35 PM
Tiny,
Thanks for the information about fish-eye eliminator. I wonder (as you do) if all brands still contain silicone.
I try to keep anything silicone-based off my vehicles. This is tough to do, especially with rubber/seal/vinyl/leather treatments. I've heard that silicone is used in most paint/rubber/vinyl treatments and can ruin a room for future paint spraying (once the room has been contaminated, you can't get rid of the contamination, I'm told).
Tim
#127844 09/13/2007 4:41 AM
my boss used to say w-d 40 could cause fish eyes if sprayed 2 days ago 3 miles away
