3 members (Bill Hanlon, joe apple, Gdads51), 93 guests, and 4 robots.
Topics128,088
Posts1,056,372
Members48,442
Also wanted to post some pics on this as well as I have found a bunch of info in the threads here that helped me. First time I have ever tore apart a transmission. Tore it all the way down and sandblasted and powder coated the case.
Fnished product
Powder coating the case
Baking the oils out after sand blasting case
Gears in the parts washer
Gears pre-wash
My first look in the trans after popping the shift cover off
What it looked like when I started
What it looked like when I started 2 with the drive shaft when I started. This is AFTER scraping with a screw driver to find the bolts!
Jason
Working on my first restomod on a 1950 3100 Shortbed (235 engine, 3 on the tree, disc brakes, etc.)
1950 Chevy 3100
Z
Z Offline
Jason....thanks for the photos...J in CT
1953 chevy 1/2 ton with 3 speed 318 on floor and 1955 235 engine
No problem. Just realized I forgot to post it is a Muncie 318 transmission with the torque tube closed drive shaft. I got my rebuild kit online from https://transmissionpartsdistributors.com/ (part #BK131) . The kit cost me a little under $94 delivered to my door and they got it to me in like 2 days, even though I just chose standard shipping.
Jason
1950 Chevy 3100
Jason,
Which kit did you use.
1. https://www.transmissionpartsdistri...ission-rebuild-kit-fits-53-69-gm-bk131a/
2. https://www.transmissionpartsdistri...d-parts-rebuild-kits/muncie-318-319.html
Did you do the rebuild?
If yes, did you use the Shop Manual and/or a transmission rebuild manual?
Did you need any special tools?
This is the kit I used: https://www.transmissionpartsdistri...rebuild-kit-fits-40-54-gm-3-speed-bk131/ (Found a 5% coupon code for them online)
The only special tool I needed was the one I made to remove the bearing retainer ring. I just welded together some angle iron. I had zero idea what I was doing, plus I am no welder but it worked like a champ.
Bearing retainer removal tool I made
I used the shop manual.
Jason
1950 Chevy 3100
