9 members (WICruiser, Youngin' Tut 59, Rick Brown, Gdads51, Hotrod Lincoln, KEVINSKI, 3800GUY, TUTS 59, 1 invisible), 106 guests, and 1 robot.
Topics128,116
Posts1,056,589
Members48,448
Carburetion specialist
When existing fuel lines are disturbed, a residue in the fuel line breaks loose. If not replacing EVERYTHING upstream of where the line was disturbed, it is a good idea to flush the fuel lines. Also, a residue builds up on the fuel pump diaphragm. If there is no pressure on the downstream of the fuel pump, the diaphragm will flex a little further, allowing this residue to flake off.
Remove the fuel line from the carburetor, and attach a temporary rubber hose to the fuel line. Place the free end of the hose in a coffee can (or similar). Pull the ignition wire so there is no spark. Turn the engine over sufficiently that the fuel pump pumps maybe a pint of fuel into the can. Use this fuel to drown ticks you remove from your dog, or start a brush fire; don't use it in an engine.
It is a good idea to replace the fuel filter at the carburetor (add one if there is not currently one in place).
Since I manufacture carb kits, I probably should not have posted this wink Then I could sell a second kit when the trash in the line stopped up the carburetor....again. wink grin
Jon
The Carburetor Shop
Thanks for the tip. I'll buy 2 kits anyway and use the other one to stamp out the fire.
And, different topic, but related:
When reinstalling your rebuilt carburetor, fill the carburetor bowl with fuel before attempting to start. A recycled squeeze mustard or ketchup bottle will suffice. Fill the bowl through the bowl vent.
Jon.
The Carburetor Shop
Moderator, Electrical Bay
Thanks Jon. Good points and generous coming from a guy who makes and sells carb kits.
~ Jon
