3 members (gswbbc, Rusty Shackleford, Gdads51), 102 guests, and 3 robots.
Topics128,047
Posts1,055,532
Members48,424
#1277740 08/25/2018 3:55 AM
This is my mockup engine. starting to line things up to make adapter plate for plenum.
That is just plain cool 😎!
I would just put that in the center of my Man Cave and charge admission for viewing it.
Thank you.
62401
Indeed. I think we need more pictures! Walk us around that thing and give us a run down on what's going on.
You, Sir, have our attention smile
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
2014 Ford E-350 4x4 (Quigley)
Moderator
Moderator
2 Offline
Cool!!
What is it going into?
Don
"The Flag Pole"
1946 2-Ton grain truck
1946 3/4-ton pickup,
1953 1-ton pickup
1957 1-ton flatbed dually,
1954 Pontiac Straight Eight
This goes in my 53 3100. This is just a mock up engine, The real one is being built. Trying to line up pulleys so the adapter from the plenum to the blower can be made. It will be 3 or 4 inches thick. With a 1/2 inch plate my carbs stick out of the hood about an inch I think so I figured if they are going to stick out it might as well be 3 or 4 inches. I think I will make a pyrex glass bubble to cover them. Will have crank fired ignition so that frees up my passenger side of engine for A/C and alt. Have serpentine harmonic balancer for accessories. Will have external oil pump belt driven off crank. Have a billet crank by Crower. I had a mid shift kit put on the TKO 600 as shown. I'm in Iowa for a few months building a dry ice plant so Won't get anything done for a while. Making more toy money. Rear end is Frankland quick change with Gleason locker. Bicknell torque arm and 12.88" Wilwood brakes all around. Nickel plated 6 piston front 4 piston rear. Electric power steering. Have a header mockup from GP headers for stainless headers. Thanks for the interest.
Any up-dates about your " 292 " .
I have an engine sitting in my shop -- maybe get to install in summer .
jim
Way to go! Looks great!
