0 members (), 100 guests, and 2 robots.
Topics128,157
Posts1,056,875
Members48,456
#1277553 08/23/2018 8:06 PM
In the old shop manuals it always says to wash your brake parts in alcohol. What type of alcohol are they talking about? Is there a better modern alternative available today. I am about to start on rebuilding my brakes on my 53 project and am curious about this.
Thanks, Mike
Mike Burns
1940 Chev 1/2 ton
1953 Chev 1/2 ton
1950 Studebaker Starlight Coupe
1947 Indian Chief
1943 Indian 741
Mike
Alcohol is preferred for flushing out the system, master cylinder, wheel cylinders and lines. For external cleaning look for Brake Cleaner in the aerosol can.
There is not a tool made that if you don't try hard enough you can't break!
1952 3100 261 T5 3.08 Gov Locker
What kind of alcohol?
Mike Burns
1940 Chev 1/2 ton
1953 Chev 1/2 ton
1947 Indian Chief
1943 Indian 741
Denatured alcohol available at your grocery store or pharmacy.
We have been using this at work, Muscle Magic, from Superior Products ( get it at O'Reillys Auto Parts ). It cuts brake dust super fast, would be good to use on everything but internal parts. Might even work for that if you dry them out good. It will clean a dirty wheel in no time!
Cleaning with alcohol is good, but don't waste your money at a pharmacy. Methanol (wood alcohol) is available at any hardware store in quart or gallon cans and it's a LOT less expensive that way. If you're planning to do any brake line flushing or other internal cleaning, stay away from any kind of petroleum-based solvents such as mineral spirits, etc. Petroleum does not play nice with rubber parts in a brake system.
After going through a dozen cans of brake cleaner on the rear brakes of my 1 1/2 ton while replacing leaking wheel cylinders, I decided to use a different method on the front. I simply used detergent, and my pressure washer, which blasted everything clean. It worked great! No dust, or hazardous fumes. Brake fluid washes away pretty good with just water, and using the pressure washer it was much cheaper, easier, and faster than other methods. It cleaned the brake linings much better than brake cleaner. Wish I would have thought of trying that years ago.
