7 members (baldeagle, Hush, mick53, Southerntruck, SmalltownTRKGuy, Hotrod Lincoln, Gray_Ghost), 102 guests, and 15 robots.
Topics128,077
Posts1,056,033
Members48,433
#1277244 08/21/2018 10:18 PM
I know there are different models of Fulton sun visors (ie. split windshield and curved windshield). Is there a way to tell what model I have? The one I have is for a split windshield.
jfjbjr #1277252 08/21/2018 11:30 PM
Best way to get help is to post a pic or two. Short of that, tell us if the end brackets have 3 or 4 screws? I might can get you in the ballpark with that bit of info.
Chuck
1941 Chevy coupe
1938 Chevy coupe streetrod
jfjbjr #1277258 08/22/2018 12:09 AM
there are three screw holes on the end brackets (dog bones).
jfjbjr #1277265 08/22/2018 12:25 AM
You most likely have the model 700 Fulton visor. If so, your dog bones should be relatively flat on one side, resembling a “B”, as opposed to being curved on both sides resembling a figure 8.
Chuck
1941 Chevy coupe
jfjbjr #1277273 08/22/2018 12:53 AM
Leo Offline
Moderator
Moderator
If you look very carefully, in the centre section, there should be a model number pressed into the aluminum. I agree, it's likely a 700.
dog bones are relatively flat on one side and they do resemble a "B". I was not able to see the model number in the center section, but I did not clean it up yet.
Leo Offline
Moderator
Moderator
My number was very faint. Clean it well and use good light.
Suggestion.......... shine a flashlight from the side at an angle towards the middle section, then put your eyes at the level of the visor and kook for the faint imprint 1953 panel told you about.
Chuck
1941 Chevy coupe
Leo Offline
Moderator
Moderator
Is your visor apart or installed? The number will not be visible if it is installed. It is on the inside.
I was thinking the same. My visor is not installed, but it is assembled.
jfjbjr #1277574 08/23/2018 10:09 PM
I took my Fulton sun visor apart. I did not find a mode number, but I did find "insert red end here" and "Insert yellow end here" on the visor. These markings are clearly visible. No other markings are evident. The paint on this sun visor seems to be the original Fulton paint.
jfjbjr #1277576 08/23/2018 10:24 PM
Leo Offline
Moderator
Moderator
Did your metal rod still have red and yellow paint on the ends?
jfjbjr #1277599 08/24/2018 12:52 AM
I did not take it that far apart. I could easily take it further apart tomorrow.
If you take it apart you might get lucky and find the model number. Sometimes when it’s assembled it covers up the lightly imprinted number. Good luck.
Chuck
1941 Chevy coupe
jfjbjr #1277637 08/24/2018 11:15 AM
Leo Offline
Moderator
Moderator
If you still need to paint your visor, you might consider painting the underside using a flat finish. It's supposed to reduce glare.
jfjbjr #1277926 08/26/2018 11:06 PM
I took my Fulton sun visor apart again and cleaned it up. I'm still not able to see any model number. The red and yellow paint is still visible on the ends of the rods that connect the visor together.
The red and yellow paint are only there to help with assembly. Without a picture I still think you have a model 700 based on your description.
Chuck
1941 Chevy coupe
