5 members (Phak1, tclederman, Charles in CA, wvstovebolt, 1 invisible), 210 guests, and 4 robots.
Topics128,083
Posts1,055,967
Members48,430
7
7 Offline
I have a 65 c10 I am just about to get on the road. I have a 3 speed on the column and the linkage is not working. When I put the linkage in the transmission it will not reach the column attachment. The transmission is out of a 68 c10. Is there a difference in the linkage? What year will work for my truck?
Does the transmission have 7 bolts on the side cover, if so it is a later model fully syncronized transmission not the original. The original had a 4 bolt side cover. The linkage will be different, you may have to bend some of your own or find something in the salvage yards, look at the 68 truck the trans came from.
Tommy
59 apache 1/2t
261 short stepside
7
7 Offline
Yes 7 bolt side cover So linkage out of a 68 will work on my 65? The problem now is the linkage is not long enough it wont reach the column from the transmission
It may work. The length of the linkage is longer on the later transmission. Measure what you have, then measure linkage on the truck transmission came from. Sometimes you have to get creative when you start mixing parts and pieces.
Tommy
59 apache 1/2t
261 short stepside
you could consider a floor shifter and do away with a jury-rigged column set up.. Vintage 3-spd shifters show up from time to time on eBay
Sir Searchalot
Sir Searchalot
What Tommy is saying is that since you have a trans from one era of truck and a column/truck from another, no linkage fit's outright. This is probably a simple modification. In these situations it would be nice to have both linkage sets. You would see what each "end" looks like and the installed tranny and column right there for the lengths. You could even weld the "ends" together and make the modified linkage or use the two sets as templates for new rod stock. Bend, thread and drill the rod stock to fit.
TomTom's idea would be easier.
The real solution is to buy and install a SM420 or SM435 4 speed truck trans. No linkage at all.
Column shifts, that need modified for a different trans, can be difficult if you are not a experienced fabricator. Maybe yours is not a difficult fabrication. Don't know. The throws, direction of lever rotation and clocking can be very different. There are limits of movement on the column side. I'm sure someone here has done it.
7
7 Offline
I am going to try the linkage from a 67-72 to see if it will work. I dont want a floor shifter because of how short most of them are and I just welded up a buchered hole in the floor from someone doing this before. Thanks for the input
Sir Searchalot
Sir Searchalot
The sm420 and the sm435 are truck transmissions with long sticks and no linkage. Suit yourself.
7
7 Offline
That would be great but i am sure my driveshaft would not work and I dont have a 420 or 435 or know where i could find one. I am almost done with the truck and wanting to sell it
Sir Searchalot
Sir Searchalot
Roger.
