| | | Forums66 Topics128,068 Posts1,055,882 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2011 Posts: 117 'Bolter | | 'Bolter Joined: Oct 2011 Posts: 117 | I have a 65 c10 I am just about to get on the road. I have a 3 speed on the column and the linkage is not working. When I put the linkage in the transmission it will not reach the column attachment. The transmission is out of a 68 c10. Is there a difference in the linkage? What year will work for my truck? | | | | | Joined: Feb 2001 Posts: 1,094 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,094 | Does the transmission have 7 bolts on the side cover, if so it is a later model fully syncronized transmission not the original. The original had a 4 bolt side cover. The linkage will be different, you may have to bend some of your own or find something in the salvage yards, look at the 68 truck the trans came from.
Tommy 59 apache 1/2t 261 short stepside | | | | | Joined: Oct 2011 Posts: 117 'Bolter | | 'Bolter Joined: Oct 2011 Posts: 117 | Yes 7 bolt side cover So linkage out of a 68 will work on my 65? The problem now is the linkage is not long enough it wont reach the column from the transmission | | | | | Joined: Feb 2001 Posts: 1,094 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,094 | It may work. The length of the linkage is longer on the later transmission. Measure what you have, then measure linkage on the truck transmission came from. Sometimes you have to get creative when you start mixing parts and pieces.
Tommy 59 apache 1/2t 261 short stepside | | | | | Joined: Jun 2006 Posts: 693 'Bolter | | 'Bolter Joined: Jun 2006 Posts: 693 | you could consider a floor shifter and do away with a jury-rigged column set up.. Vintage 3-spd shifters show up from time to time on eBay | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | What Tommy is saying is that since you have a trans from one era of truck and a column/truck from another, no linkage fit's outright. This is probably a simple modification. In these situations it would be nice to have both linkage sets. You would see what each "end" looks like and the installed tranny and column right there for the lengths. You could even weld the "ends" together and make the modified linkage or use the two sets as templates for new rod stock. Bend, thread and drill the rod stock to fit.
TomTom's idea would be easier.
The real solution is to buy and install a SM420 or SM435 4 speed truck trans. No linkage at all.
Column shifts, that need modified for a different trans, can be difficult if you are not a experienced fabricator. Maybe yours is not a difficult fabrication. Don't know. The throws, direction of lever rotation and clocking can be very different. There are limits of movement on the column side. I'm sure someone here has done it.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Oct 2011 Posts: 117 'Bolter | | 'Bolter Joined: Oct 2011 Posts: 117 | I am going to try the linkage from a 67-72 to see if it will work. I dont want a floor shifter because of how short most of them are and I just welded up a buchered hole in the floor from someone doing this before. Thanks for the input | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | The sm420 and the sm435 are truck transmissions with long sticks and no linkage. Suit yourself.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Oct 2011 Posts: 117 'Bolter | | 'Bolter Joined: Oct 2011 Posts: 117 | That would be great but i am sure my driveshaft would not work and I dont have a 420 or 435 or know where i could find one. I am almost done with the truck and wanting to sell it | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 |
