0 members (), 67 guests, and 3 robots.
Topics128,055
Posts1,055,782
#1277143 08/21/2018 6:03 AM
Hi All,
I have a 1/2 1950 chevy truck. I purchase fender welting from one of the vendors, cannot remember which one. I realize I have to cut out pie shaped notches to get it to contour the fender shape. I am trying to install the from fenders but welting material does not seem wide enough. I is not wide enough to use the mounting holes on the fender or on the cab sheetmetal. I this correct? I always thought the mounting screws would pass through the welting material to help keep it in place. May be I am not understanding how to install it. I have done a search but did not see anything on the front fender installation.
thanks,
skipper
How wide is the welting (outward from the "cord")?
Can you attach a picture (with a ruler next to it)?
What vender and part number?
If it is listed/shown on-line, post a link to it.
The replacement welting is not as wide as original
You will have to pie cut it and cut out holes
...pic...
I notch them with pie cuts and cut off the ends of the pie pieces which interfered with the bolt holes. I then use all seven of my hands to hold the welting in place while tightening the fender bolts. (I use my other two extra long arms which have the extra reverse bend elbows for tightening those bolts.) Can you smell "Tech Tip" nominee?
Carl
I would like to see a video of that Carl.
I measured my welting, the edge is 1.25" from the tubing edge. I believe I purchased it from Classic Truck. Dads50, I see from you picture that the front welting, the fender mounting holes do not go through the welting. Did you use adhesive to keep it from sliding around?
I used a little bit of weatherstrip adhesive to affix the welting correctly on the flange of the fender. Pie cut the welting to curve, and to miss bolt holes. Once adhesive is dry, easy install.
1940 Chevy KC 1/2-Ton
I just used the tape seen in the pic, once the bolts we in I fished it out.
small amount of adhesive sounds like a good Idea
I just wanted it kinda loose so I could readjust as needed
Skipper thanks for starting this good conversation , Based on your experience, Dads50, 52Carl, and Britcon, do you think these ones from Chevs of the 40's would work without modification?
https://www.chevsofthe40s.com/dept/Fender/cat/Gaskets.html
see 609725 part number on the page
Ron - - Dusty53
1954 Chevy 3604
Ronnie,
Jim Carter sells the same ITEM for half the price. I used these on my truck and they worked great. This is for the inner fender.
Harold
NOTE
The item in my post is in reply to Ronnie asking about The gasket set for the inner panel with lower rear mount pads.
Harold
Both of those seem to be missing the distinctive bead
But its had to tell from the pic
I didn't worry about the fender bolts going through the welting when I installed it on my fenders. I just relied on the pinch pressure of the fenders to hold the welting in place. I have not had any issues. It has been in place for about 2 years.
Dave from Northern Kentucky
My 54 3100
