2 members (54farmtruck, Rich'sToys), 115 guests, and 1 robot.
Topics128,157
Posts1,056,875
Members48,456
#1276583 08/16/2018 10:13 PM
2 Offline
Hi I’m back with a simple or dumb question...
I want to put aluminum pistons into my 216 engine
After some research seems I can buy them for about $50 or less each online, but anyone know the best place with decent reputation to source that?
Alternatively... and I might be crazy here,
But suppose I have access to a lathe and I have many extra aluminum 235 pistons laying around (which I do) if I cheaped out on this idea could I just take about 0.06 off those 235 pistons and squeeze them in with std rings into my 216? Or would I need to absolutely use 216 rings for the diameters and widen my ring grooves on the piston to accommodate?
This project isn’t a performance engine or nothing, I’m just daydreaming of saving a few dollars with the stuff I got already that’s just takin up space.
Thanks for any inputs
-s
Just bore the 216 block 60 over (actually .0625") and use the 235 pistons "as is". You'll increase the displacement to 224 cubic inches, raise the compression slightly, and reduce the tendency for the Babbit rods to wear as rapidly due to the lighter piston weight. You'll also be able to turn a few more RPM without beating the rods to death. Unless you've got a cam-grinding machine, simply turning the pistons on a lathe won't work- - - -the piston skirts aren't round. Their widest point is at right angles to the wrist pin, and the piston gets round as it heats up because it has an Invar anti-expansion strut cast into the piston pin boss on both sides.
2 Offline
Thanks for the suggestion Jerry I’ll follow up on that solution as I’m not sure the minimum cutting needed yet to get the ridges out of my block. But going up to 235 diameter would definitely take all the bad out.
-s
Those blocks are pretty thick- - - -80 or even100 over doesn't present much of a proble4m as long as the cooling system is in good shape. You also get to run standard bore 235 rings without doing any butcher work on the pistons.
Egge.com is a good source for all internal engine parts. I bought my pistons there for my 235.
58' 3200 235 3-speed/OD
Egge should include a quart of Vaseline with all their orders!
Ex Hall Monitor
Ex Hall Monitor
I got my aluminum 216 pistons from Kanter. For that fact I got the whole overhaul kit from them. Lifetime guarantee.
