3 members (Cosmo, JW51, 1 invisible),
131
Mod | | | Forums66 Topics128,080 Posts1,055,956 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2012 Posts: 222 'Bolter | | 'Bolter Joined: Sep 2012 Posts: 222 | What should the resistance be for a 12volt 235 coil with points setup? I'm having trouble with my truck just dying as I'm driving it. I suspect the pertronix ignition as being the problem and want to change back to points to see if it helps. The coil I have with the Pertronix measures 1.6 ohms and a resistor in line. I have a spare 57 235 that the coil measures 3.6 ohms with the resistor in line. Which one should I be using. They both say 12 volts on them. Dave | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | What is the Pertronix part number? | | | | | Joined: Feb 2004 Posts: 29,780 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,780 | A simple Ohm's Law calculation tells me that before such things as inductive reactance get figured into the mix the 1.6 Ohm coil will flow 7.5 amps at 12 volts- - - -WAY too much for a set of points to handle. At a a normal charging system voltage of 14.5, the coil will flow just over 9 amps and the points will be crispy critters in a matter of minutes. The 3.6 Ohm coil will flow 3.3 amps at startup, and 4.3 amps during normal running- - - -much better, since the max a set of points is supposed to carry is 5 amps.
There are two types of Pertronix ignition systems- - - -the failed ones, and the ones that are going to fail soon. Jerry
| | | | | Joined: Sep 2012 Posts: 222 'Bolter | | 'Bolter Joined: Sep 2012 Posts: 222 | Tim I'm not sure of the part# as it's about 10 years old. but it is a Pertronix 1. Jerry, should I use the 3.6 ohm coil with the resistor? Dave | | | | | Joined: Feb 2004 Posts: 29,780 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,780 | I think so. Is the resistor external, or built into the coil? Normally, a GM "12 volt" coil is supposed to have an external resistor. "Internal resistance" 12 volt coils are for Fords. Voltage at the coil + terminal with the engine running needs to be around 9-10 volts. With the resistor bypassed during cranking you should see almost full battery voltage - - - -around 11.5-12 volts, usually. A good way to check primary voltage during cranking is to take the high voltage coil wire out of the center of the distributor cap and ground it, then crank the engine for a few seconds and monitor the voltage at the coil.
| | | | | Joined: Sep 2012 Posts: 222 'Bolter | | 'Bolter Joined: Sep 2012 Posts: 222 | It is an external resistor. I'll install the parts this weekend and do a voltage check like you suggest. Thanks for the info. Dave | | | | | Joined: Sep 2012 Posts: 222 'Bolter | | 'Bolter Joined: Sep 2012 Posts: 222 | Jerry, The engine is in a 49 truck with the foot starter. This system doesn't use a higher voltage during cranking does it? Dave | | | | | Joined: Feb 2004 Posts: 29,780 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,780 | It should, but you'll probably need to install a foot start switch with the small terminal on the side. Rock Auto has them at a reasonable price. A wire is run from the small terminal to the (+) terminal of the coil, and bypasses the resistor to provide full battery voltage during cranking. That switch was used on foot-start 12 volt 235/261 applications, so it's the best way to do things when a 12 volt ignition system is used, even on a conversion of a 6 volt truck. Jerry
| | | | | Joined: Sep 2012 Posts: 222 'Bolter | | 'Bolter Joined: Sep 2012 Posts: 222 | | | | | | Joined: Oct 2006 Posts: 1,847 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 1,847 | the best way to fix it is take out the pertronix and use the points. I have tried pertronix in my mustang, and my truck, the mustang failed the first time I used it, the truck failed on the way to the dump. After finally getting my wife to go with me and my daughter, I got to stand out in the rain learning how to navigate the bus system in our town. I had all the parts to put the points back, in a bag in the glove box. But had taken it out earlier for some reason, and forgot to put it back in. Then I got to go stand in the rain a little bit more swapping everything back. In 35 years the only time the truck failed to make it home was after I UPGRADED the ignition. I have had gas pouring out of the carburetor, I have had pushrods fall out, due to exhaust valves sticking open because of a poor but expensive rebuild, but it always made it home. There is no amount of festering with points that will ever be as much trouble as that day. I asked the question directly on 2 different forums. Of the replies I got, it was about 60% failure rate. Not to mention it didn't run any better. If for some reason you feel you really NEED to replace the points, use langdons HEI. | | | | | Joined: Jan 2013 Posts: 1,518 'Bolter | | 'Bolter Joined: Jan 2013 Posts: 1,518 | Brokenhead, well said. Pertronix left me stranded in my 62 impala at Longbeach Washington with my family of five on a sunday. A passerby gave me a ride down to an old style grocery store down the road, he said they had some car parts. I have only been lucky twice in my life, the day my wife said I do and when I laid eyes on an old dusty box on the shelf with a gm set of points inside. Owner said those points had been on the shelf since the sixties and it was 1994,lol. He even had a match book so I could gap them. I'll stick to points or a GM Hei any day too. They can have every and any aftermarket ignition. IMHO. 1953 Chevrolet 3100261 cu inch, sm420, 3.55 rear, torque tube still,omaha orange, still 6 volt, RPO green glass, side carrier spare, all done In the DITY GalleryVideo of the 261 running1964 GMC 1000305 Big Block V6, sm420, the next cab off restoration
