3 members (Hotrod Lincoln, baldeagle, 1 invisible), 67 guests, and 9 robots.
Topics128,020
Posts1,055,345
Members48,420
#1275768 08/11/2018 12:57 AM
V
V Offline
Ok, I can't find a shop manual or any info on the web about the specs for this engine, as far as tune up parts go. Does anyone know what specific points, condenser, cap, rotar, oil filter, etc. I need? Also the point and plug gaps? I can't believe I can't find any of this info anywhere. Any help appreciated.
Tyler
Verdigris #1275770 08/11/2018 1:10 AM
H Online: Content
I believe the same points and condenser, and possibly the distributor cap and rotor will interchange with a distributor for a 235. The 426 is the smallest of the "big" GMC engines, with the 503 being the largest one. Ed Pruss has a 1954 630 series truck with a 503 in it. You might want to send him a private message to see what information he might be able to provide. I drove that truck from south Tennessee to the reunion in Kansas city a few years ago after Ed broke down on his way from Cullman Alabama to Denver. Quite a trip! I changed the points partway, and the ones I used were identical to points for a 235. A point gap of .016" and a plug gap of .035" will get you on the road- - - -not sure if that's perfectly accurate, but it's in the ball park.
Verdigris #1275795 08/11/2018 2:24 AM
http://oldcarmanualproject.com/manuals/GMC/1954/620-980/Section8/section8.pdf
Some info here. Maybe the website has more info..
BaconFarms
1948 GMC 2 Ton
1958 GMC 370-8
1965 GMC 5000
1970 Chevrolet C50
Verdigris #1275818 08/11/2018 10:29 AM
V
V Offline
Thanks for the info, Jerry. You think that plugs for a 235 would work also?
Bacon farms, I found that site earlier but can't access it. Wish I could, it looks like what I need.
Thank you both.
Tyler
Verdigris #1275845 08/11/2018 3:45 PM
H Online: Content
On a big, low-compression engine like the 426, about all that a spark plug needs to do is light the fire. As long as the thread diameter and length is correct, there should be a wide range of plugs that will work, especially if you're not planning to do a lot of hard pulling at max RPM and wide open throttle like these engines were designed to do. As long as the plugs don't foul out from being too "cold" of a heat range, you should be good to go.
Verdigris #1275869 08/11/2018 7:06 PM
AC 44 spark plugs, gap, 0.028"-0.032"
BaconFarms
1948 GMC 2 Ton
1958 GMC 370-8
1965 GMC 5000
1970 Chevrolet C50
Verdigris #1275885 08/11/2018 11:33 PM
V
V Offline
Thanks Jerry and BF for the info. Now I at least know some basics.
Tyler
Verdigris #1275892 08/12/2018 12:22 AM
Bond Villain
Bond Villain
Tyler
Congrats Tyler! Now you are ahead of a lot of us wink
eeeek
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
2014 Ford E-350 4x4 (Quigley)
Verdigris #1275903 08/12/2018 2:05 AM
318, is actually the smallest, of the group, and the 707, is the largest.
Spanky Hardy
More pictures on Photobucket
1950 GMC 250 1-Ton
Verdigris #1275909 08/12/2018 3:35 AM
3B Offline
Hy Guys, I know we are talking about the medium and heavy duty truck engines here, but the smallest displacement of that design of engine, manifolds on the right side of the block and removable cylinder bank was a 278 I believe and there was a 308 as well, I have a 308 in a 1948 500 series GMC.
Verdigris #1276028 08/13/2018 1:56 AM
Crusing in the Passing Lane
I think there was some kind of break as the engines got larger, no clue where it was, but somewhere they looked the same but got physically larger, perhaps larger than 308?
Ed
Verdigris #1276037 08/13/2018 3:08 AM
H Online: Content
I seem to remember a late 1940's/early 50's GMC road tractor owned by my uncle that had a big gasoline engine with the carb on the passenger's side. I believe it had some sort of updraft carburetor, but that might not be the case. It was a conventional cab rig, not a cabover. He used it to pull a trailer for the big freshwater boats he repaired at his shop near Old Hickory Lake, near Nashville.
Verdigris #1276116 08/13/2018 7:41 PM
My spare 503 distributor is driven by a rectangular shaft crosswise through a vertical 3/8" pin that extends out the bottom of the housing. The rectangular shaft is offset slightly from the center of the 3/8 shaft, one must be careful when inserting in block.
Innards of distr. are probably same as other GM distributors, however.
Ed
Verdigris #1276391 08/15/2018 4:32 PM
1950 was the year GMC Heavy Duty Trucks, introduced the new style Cabs. Along with the new cabs, came the new engines. 318, 360, 426, 503, and 707. Before 1950, the Heavy Duty gas engine group, consisted, of these engines. 308, 361, 451, and 477.
Spanky Hardy
1950 GMC 250 1-Ton
Verdigris #1276410 08/15/2018 6:37 PM
V
V Offline
Thanks for the info, Spanky. Is there a good book out there for info on these early, bigger series trucks?
Tyler
Verdigris #1276462 08/15/2018 11:39 PM
Moderated
Moderated
Sorry Spanky, but the 426 engines were out before 1950. In 1950 they bored out the 426 or 477 block to 503. My 1948 ACR 723 has a 426.
Tyler get GMC Maintenance Manual 520 & up. You can find them on ebay. It has all the info you need for your 426.
Dennis
Verdigris #1276481 08/16/2018 1:59 AM
Search ebay, for GMC Maintenance Manuals models 520-970, or 620-980. There's several on there.
Spanky Hardy
1950 GMC 250 1-Ton
Verdigris #1276490 08/16/2018 2:38 AM
GMC 630's came with 503's, which are just slightly larger, similar engines. Parts and service manuals are frequently available on EBay, that is where I got mine.
Ed
Verdigris #1276569 08/16/2018 7:55 PM
V
V Offline
Found and ordered a manual on e-bay.
Thank you all for the help. You guys are great.
Tyler
Verdigris #1276608 08/17/2018 12:41 AM
Be careful, head gaskets and gasket sets are hard to find for 426's or any other big blocks, makesure your head bolts are tight (80 ft. ft. pounds for .437 bolts, if .437 bolts less, )
ARP has.437 head bolts, slightly long, but OK.
Ed
Verdigris #1276695 08/17/2018 8:31 PM
V
V Offline
Where would you find a head gasket for a 426? E-bay? Maybe I should start looking now just in case.
I'll retorque the head bolts so I know where I'm at. Thanks again for the info Ed.
Tyler
Verdigris #1276763 08/18/2018 12:21 PM
No known head gaskets, there was a fellow in WA a while back that had some 'space age material' that he made head gaskets out of, Stewart or Stevenson or something like that was his name.
Ed
Verdigris #1276803 08/18/2018 6:29 PM
Leo Offline
Moderator
Moderator
Try Al Lambert at Gasket City in Hamilton ON.
Verdigris #1276817 08/18/2018 7:56 PM
H Online: Content
Ditto on Gasket City. I got the last valve grind gasket set he had in stock for Ed's 503 about 3 years ago, but at that time he had ONE head gasket left for the same engine. I believe the 426 and the 503 use the same head gasket, but I'm not sure of that.
Verdigris #1276853 08/19/2018 1:45 AM
V
V Offline
Thanks guys. I'll check into Gasket City.
Tyler
Longnose Jimmy., I'm just passing along what the GMC Catalog says, I wasn't born yet, so I can't tell for sure.
Spanky Hardy
1950 GMC 250 1-Ton
