2 members (Bill Hanlon, Stovebolt48), 67 guests, and 2 robots.
Topics128,036
Posts1,055,458
Members48,422
#1276431 08/15/2018 10:04 PM
i have a 250 6cy in my 51 3100 there use to be a vacum pod that operaded a internal heat riser , by the lever on the out side of the exhust manifold any idea how to tell if its open or closed
H Online: Content
Doesn't matter- - - - -all that head is good for is an anchor for a medium-sized boat! The way it's supposed to work is the flap valve will be in the "hot" position pulling against a spring when vacuum is applied, and a thermal valve cuts the vacuum off when the thermostat opens and vents the line when the engine reaches operating temperature. The default position is "cold" to prevent detonation if there's a vacuum loss for some reason. That vacuum valve will not function properly without at least a 195 degree thermostat. The whole mess was a Rube Goldberg method of trying to meet EPA exhaust emission standards during warm-up. Installing an earlier cylinder head/manifold assembly with a regular thermostatic coil heat riser would be a much better option.
thanks just trying to have it open there is no vacum pod spring or anything other than the lever that controls it
H Online: Content
Shine a light up into the open end of the manifold where the exhaust pipe bolts on and watch the valve move. Then block the linkage in whatever position gives the best gas flow. It's been a lot of years since I worked on one of those emission-control engines, so I don't remember which way to move the lever for "open".
X2
integral head / manifold 250 tend to like to crack, & the Vari-jet carb is a pain (IMHO),
BC
1960 C60 pasture art
H Online: Content
The vara-jet secondary metering rod has a nasty habit of wearing out the ball joint where it attaches to the air valve and falling into the intake. It usually gets imbedded in a piston crown and makes some interesting knocking noises as it batters the cylinder head.
well im guessing its time to look for another head along with intake and exhust manifold thanks for the heads up
i just had a new exhaust system put on the truck while it was on the houst i looked couldnt see it as it only afex the number 1 and 2 cyl the reason im asking when i run the truck about 55 or 60 for a while it starts acting like its loading up and i was thinking that flapper was closing and causign the problem... i guess ill have to split the exhust so i can get to it thanks for all the great info on this motor
