| | | Forums66 Topics128,066 Posts1,055,875 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2007 Posts: 51 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2007 Posts: 51 | I've bent the throttle linkage on my 53 P/U with a 235. took it off straightened it but the install is a big hassle, Has anybody hooked a cable throttle with new pedal assemble to a rochester B carb? I've had another card on it and had to shorten the rod to the carb,,thread it and use different pieces to hook it up. Never really got full throttle and rubbed a little on the exhaust header. Getting it out from behind the exhaust pipes would be a time saver, Anyone changed over to cable and eliminating the original linkage?
[url=http://www.stovebolt.com/gallery/shannon_joe_1953.html]1953 Chevy 3100[/ur When life looks like easy street there is danger at your door
| | | | | Joined: Feb 2004 Posts: 29,777 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,777 | There should be plenty of cable pedals available, either salvage yard or aftermarket like JEGS or one of the other race equipment suppliers. Just do a little geometry homework and figure out how much cable travel you'll need to get smooth operation from idle to wide open throttle and fabricate some bellcranks. Be sure you've got a good return spring right at the carburetor- - - -a broken cable or a slipped clamp can increase your pucker factor if the throttle doesn't close right away! Jerry
| | | | | Joined: Sep 2007 Posts: 51 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2007 Posts: 51 | I got the old linkage put together. Just told myself it wouldn't be an hour job. You know, that's one part that is hard to get a photo of it all hooked up
| | | | | Joined: Mar 2010 Posts: 10,275 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,275 | Good work Joe! Nothing I can think of works as good as the original setup when all the parts are there, not bent out of shape, and actually the one made for your truck. Carl
