| | | Forums66 Topics128,076 Posts1,056,280 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#12760 08/15/2002 5:54 PM | Joined: Jul 2002 Posts: 188 Member | | Member Joined: Jul 2002 Posts: 188 | In my long search to find a pumpkin for my 50 3600 I just found 3!2 are standard and 1 is a posi-trac. The junkyard thinks the positrac will bolt in, but wants me to count the number of splines on my axel. That I can do tonight, but I wondered if any one knew off the top of their head. If it will fit there is an advantage, but what are the down sides?? Any help would be greatly appreciated. What can you tell by looking at a used pumkin?? | | |
#12761 08/15/2002 6:38 PM | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | The unit you are referring to has a Detroit Locker in it. The down side is that it will cause increased tire wear and possibly some loss of control in slippery conditions(ice/snow,etc) The up-side is that it will have better traction.It will make some clunk/bang noise when it goes around corners under heavy throttle but that is normal. How much are they asking for the unit and what gear ratios are the units?
#12762 08/15/2002 7:14 PM | Joined: Jul 2002 Posts: 188 Member | | Member Joined: Jul 2002 Posts: 188 | 4:10 $175 FOR STANDARD, $250 FOR POSI-TRAC. THIS IS A VERY COUNTRY YARD AND WILL DICKER. I'M NOT MARRIED TO THE POSI, BUT HAVE NEVER SEEN IT MENTIONED ON ALL THE FORUMS. | | |
#12763 08/15/2002 9:32 PM | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | Here is at least one Rear end swap ANd this is what I got when I typed in the search for "Rear-End" Rears
