9 members (Samantha, Forty9, texas46, Rustnut, IHPWR, Bill Hanlon, DadsFirstPickup, 32Fordpuchoptop, 1 invisible),
140
Mod | | | Forums66 Topics128,108 Posts1,056,236 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2011 Posts: 523 Shop Shark | | Shop Shark Joined: Apr 2011 Posts: 523 | Had the truck running well enough to take it to the muffler shop to have the second half of the tail pipe made and then next door for a GOOD tune up. He repositioned my distributor by one tooth, determined that my vacuum advance was not working (one on the way from Jim Carter), adjusted the carb, and got the idle down to 650. He also sold me a re-buildable Rochester B (manual choke) to replace my BC (auto-choke). All for $100. He seemed to think my 55 engine had a 59 flywheel. Now to spend my time on minor issues, like a weak brake system.
Life is good again. Bob
BobS46
| | | | | Joined: Jan 2011 Posts: 237 'Bolter | | 'Bolter Joined: Jan 2011 Posts: 237 | | | | | | Joined: Jul 2018 Posts: 9 New Guy | | New Guy Joined: Jul 2018 Posts: 9 | Sounds great that your engine is running smoothly now. Weak brakes don't sound too much like a minor issue though when you need to stop and the truck only sorta slows down.
1954 3600 three window
