3 members (Gdads51, TUTS 59, 1 invisible), 119 guests, and 8 robots.
Topics128,088
Posts1,056,124
Members48,435
What do you suppose would cause no compression at all? Compression is #1 - 100, #2 - 105, #3 - 102, #4 - 0, #5 - 112, #6 - 105.
From the vacuum gauge I noticed one of the cylinders didn't seem to be firing so I ran a compression test. This seems like a big problem to me. Would it be a broken ring?
The engine is a 216 rebuilt with maybe 1000 miles. The temperature gauge suddenly spiked going up a hill, and then seemed to lack a bit of power.
Could be a valve problem,bent push rod, check the valve train out/ You may find the problem fast
!956 Gmc Napco 4x4 Factory line built .
V
V Offline
I'll 2nd a valve problem. Either the intake or exhaust valve isn't closing all the way. The valve could be bent and sticking, burnt and not sealing or has some carbon or other material keeping it from closing or adjusted too tight.
Remove the valve cover and go through the valve adjusting procedure on cyl #4.
If that doesn't correct it then do a leak down test on cyl #4 and listen to the exhaust and intake to determine where the air is leaking out.
Good luck
Dave
Do a dry/wet compression test. If you have the same reading on #4 when it is checked wet, it is your valve. Is there water in the oil? if so it is either a blown head gasket or cracked head.
1946 1-ton Panel
1952 1-ton Comml. W/Grain Body
Broken rings usually won't drop the compression all the way to zero. That takes a badly burned or stuck valve, or maybe a hole in a piston. Air pressure at the spark plug hole with the piston near top dead center on the compression stroke will pinpoint the source of the leak. Put the transmission in gear and set the parking brake, or clamp the flywheel to keep the air from turning the crankshaft.
The exhaust valve was waaaay too tight. Maybe someone accidentally adjusted the exhaust valve to intake specs.
Thanks, problem solved!
