5 members (Gray_Ghost, 49choptop, Guitplayer, pauld, Forty9), 101 guests, and 4 robots.
Topics128,201
Posts1,057,281
Members48,467
replaced the side vent gasket the other day was a snap. but whats the easiest was to replace to top vent gasket?? do i have to remove it to replace it??
nothin like ol' Chevy iron..keep it goin
1948 Chevy Loadmaster Flatbed
Ex Hall Monitor
Ex Hall Monitor
I figured someone with a 48 woulda been on this one already. ohwell I don't know if your 48 is exactly the same as my 38 but mine will require removing the vent assembly to facilitate cleaning off the old gasket remains and installing the new one. If yours allows enough access to scrape out & clean the mounting surface without removing the vent assy. you might be able to drop the new gasket in some boiling water to soften & stretch it over the vent. If that works you'll need to let it cool & dry before sticking it down. I'm not recomending that, I've not done that. It just seems like it "might" work.
