0 members (), 132 guests, and 0 robots.
Topics128,048
Posts1,055,540
Members48,425
Years ago, when my dad owned the 59, he fabricated this modification so that a simple modern day spin on oil filter could be used instead of the cartridge filter in the external filter setup.
Here's some pictures that kind of tell the story. Not exactly sure how he manged the return line to the block, but maybe you guys can tell.
~~ Darcy
1959 GMC 9310 Canadian- built Shortbox Fleetside Deluxe
FootStomper
In the Project Journals Forum
Bolt the old filter wrench to the cap.
~~ Darcy
FootStomper
I just screw the filter in place without the lid attached.
Once I get it as snug as my fingers will allow, I put the lid on and use a wrench to give it a quarter turn to tighten.
~~ Darcy
FootStomper
One little mod I made today.
I destroyed one of my many magnetic retrieval tools and salvaged the earth magnet out of it. Stuck it to the end of my oil pan drain plug.
It was a little tricky going through the pan threads as it wanted to grab them until I got the plug in far enough to get past them.
~~ Darcy
FootStomper
Nice mod. I put a remote adapter for a spin on, on my 54 235 but I could never get a proper oil pressure reading so I took it off and run without a filter 10 years now. I might look into what your dad did.
Ron, The Computer Greek
I love therefore I am.
1954 3100 Chevy truck
2017 Buick Encore
See more pix
Oil pressure gauge works perfectly with this set up by the way...
~~ Darcy
FootStomper
H Online: Content
It's an interesting way to get less efficient oil filtering. The media in a full flow filter has such a loose weave that it lets a lot of stuff flow through that the original filter would trap. Now, if you could adapt a spin-on Diesel fuel filter to an original-equipment housing like that, you'd be able to combine the advantages of a spin-on filter and the fine-particle filtering usually associated with a bypass filter.
