| | | Forums66 Topics128,104 Posts1,056,201 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2003 Posts: 1,061 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 1,061 | Any comments on painting a radiator? Just got mine back and the shop asked if I was going to paint it. Hadn't given it much thought but it sounds like a good idea
1946 1-ton Panel 1952 1-ton Comml. W/Grain Body | | | | | Joined: Jan 2017 Posts: 308 'Bolter | | 'Bolter Joined: Jan 2017 Posts: 308 | I like the Brass finish showing on my 49--paint the rest. | | | | | Joined: Feb 2004 Posts: 29,799 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,799 | Be sure to use a paint that's specifically designed for radiators, and don't coat the fins heavily. Some paints serve as insulators and will interfere with heat transfer. Also, spray at about a 45 degree angle so only the first fraction of an inch of the fins actually gets painted. Jerry
