| | | Forums66 Topics128,068 Posts1,055,883 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2018 Posts: 16 'Bolter | | 'Bolter Joined: Jun 2018 Posts: 16 | Where can I buy a wiring harness for 1950 4400 6 or 12 volt?
Brad1950 4400
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Original circuits.only? Do you want braided wiring? | | | | | Joined: Jun 2018 Posts: 16 'Bolter | | 'Bolter Joined: Jun 2018 Posts: 16 | Good evening Tim Yes braided I’ve called several places and companies did not have anything for a 4400.
Brad1950 4400
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | The 1950 4400 cab and engine compartment is the same as on a 1/2 ton to 1 pickup truck. Those braided harnesses should be available?
The major wiring difference for your truck would be the wires to the rear lamp?
Maybe they could make a longer, braided, rear lamp wire. Maybe slightly longer front lamp leads would also be needed?
Maybe some else can confirm this, and/or can explain other differences?
| | | | | Joined: Aug 2009 Posts: 311 'Bolter | | 'Bolter Joined: Aug 2009 Posts: 311 | I bought a cloth covered wire set from Jim Carter a couple years ago for my '48 4400. The rear light need to be modified as it was to short, otherwise everything works great. Curt | | | | | Joined: Jun 2018 Posts: 16 'Bolter | | 'Bolter Joined: Jun 2018 Posts: 16 |
Brad1950 4400
