4 members (Phak1, MNSmith, 2 invisible), 76 guests, and 3 robots.
Topics128,180
Posts1,057,141
Members48,463
Ok, I picked up this truck yesterday. No title, it has a 64 5 6 cab, '63 grille, and a squarebody drivetrain. I figured it was a 60-66 body dropped on a squarebody k10 chassis, but after looking, it's definitely a factory '60-'62 maybe '63, so I bought it (I've been wanting a k10 frame for my '63c10 for a long time).
The main thing I'm using to date this frame is that the front engine crossmember has the mounting plate for a 235. It is still riveted in the frame, so it's got to be original.
So here's the question. Did '63 k10's come with the 235?
I know the 2wd trucks went to the 230/292, but somewhere in the recesses of my mind I think I remember reading something about the '63 k10s still having the 235.
Also, I'd love to see a factory bellhousing crossmember. I crawled under there expecting to see it torched off, but it looks like there are brackets on each side with 4 holes that a crossmember would bolt to. I was assuming it would be just like the 2wd, so that took me off guard. It looks like the factory T221 crossmember is still bolted up as well.
The front cab mounts are still there, but the rears were cut off and re positioned. I know I've read something about the differences in rear cab mounts between the 60-63 vs 64-66, so I'm guessing that's the reason that was done.
As far as the rest of the truck drivetrain, someone put in a 350/350/208 with a later model dana 44 and a 14 bolt.
Plans right now are to strip it down to the frame and springs, part out the drivetrain and body (the body is really rotted out), clean it up (there's a lot of crap welded on to the frame), and build it for my c10 body.
Pics
truck
http://67-72chevytrucks.com/vboard/attachment.php?attachmentid=1797581&stc=1&d=1530467641
235 mount
http://67-72chevytrucks.com/vboard/attachment.php?attachmentid=1797582&stc=1&d=1530467677
trans cross member brackets
http://67-72chevytrucks.com/vboard/attachment.php?attachmentid=1797583&stc=1&d=1530467677
Front cab mount
http://67-72chevytrucks.com/vboard/attachment.php?attachmentid=1797584&stc=1&d=1530467697
rear cab mount
http://67-72chevytrucks.com/vboard/attachment.php?attachmentid=1797585&stc=1&d=1530467697
Liquidated my projects
Now looking for a decent '47-'55.1 3100, 3600, or 3800
Thanks, I knew I had seen that somewhere
X
X Offline
1966 K20 long bed
I would be interested in a picture and length of the steering drag link. Would like to date one of mine.
~ HB
1962 Chevrolet C10
1962 Suburban
jat Offline
Moderated
Moderated
I own a 1963 K10 with a 261. It has 82K miles, is 98% original & unmolested. I believe the 261 was the standard engine for K10s in 62. Mine was built in July of 62 & has a 62 style steering column. It could have been ordered this way or maybe it is so early in the production run they used leftover parts? The truck looks exactly like the K1534 LWB fleetside shown page 2 of the1963-Original-Chevrolet-Truck-4-Wheel-Drive-Models-Sales-Brochure listed on ebay.
