7 members (Guitplayer, JW51, mo2cyl, Otto Skorzeny, 55shaker, Wally / Montana, 1 invisible),
73
Mod | | | Forums66 Topics128,050 Posts1,055,757 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2008 Posts: 1,644 'Bolter | | 'Bolter Joined: Jun 2008 Posts: 1,644 | I’ve noticed that lately the choke cable on my ‘50 216 is difficult to pull out during the starting process. It does not appear to be in a bind, nor does it have any kinks in it. What’s the best way to lubricate the cable? Is the wrapped sheath around the cable porous so that I can just spray some WD-40 on it to solve the problem?
Thanks!
Chuck 1950 Chevy 1/2 ton (all original) 1951 Chevy 1/2 ton (future streetrod) 1941 Chevy coupe 1938 Chevy coupe streetrod | | | | | Joined: Apr 2005 Posts: 7,440 Bolter | | Bolter Joined: Apr 2005 Posts: 7,440 | Do you have a plastic coating on your cable? If not just give it a good spray with whatever lube you’ve got.ðŸ›
| | | | | Joined: Jun 2008 Posts: 1,644 'Bolter | | 'Bolter Joined: Jun 2008 Posts: 1,644 | It looks like a ribbed, steel covering. No plastic.
Chuck 1950 Chevy 1/2 ton (all original) 1951 Chevy 1/2 ton (future streetrod) 1941 Chevy coupe 1938 Chevy coupe streetrod | | | | | Joined: Jun 2006 Posts: 693 'Bolter | | 'Bolter Joined: Jun 2006 Posts: 693 | had the same problem with my spiral-cased choke cable a few months back (there is a thread here about it). i pulled out the cable from the sheath and gave everything a good spray with Kano Penephite Graphited Penetrating Oil and it all works as smooth as butter now. | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Also put a few drops of oil on the shaft where it goes into the dash. It also helps to step on the gas pedal a little ways before pulling out the choke so the fast idle cam is not opening the throttle. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Apr 2008 Posts: 899 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 899 | I was able to massage clear plastic tubing over my spiral encased cable after giving it a good cleaning as noted above. Worked for me.
Ed
| | | | | Joined: Feb 2004 Posts: 29,771 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,771 | A trick we used to use on motorcycle throttle and clutch cables was to prop the end of the cable up in a vertical position as high as possible, make a small funnel out of duct tape, and fill the funnel with lightweight oil. Gravity flow overnight would lube the entire length of the cable. Use oil, not WD-40 if you want the lube to stay there awhile. Jerry
| | | | | Joined: Jun 2008 Posts: 1,644 'Bolter | | 'Bolter Joined: Jun 2008 Posts: 1,644 | Thanks everyone. I’m on my way to give it a try!
Chuck 1950 Chevy 1/2 ton (all original) 1951 Chevy 1/2 ton (future streetrod) 1941 Chevy coupe 1938 Chevy coupe streetrod | | | | | Joined: Feb 2016 Posts: 1,985 'Bolter | | 'Bolter Joined: Feb 2016 Posts: 1,985 | Pull the cable out of the housing and use some fine sandpaper on the wire running lengthwise down the cable. Shoot some brake cleaner or carb cleaner down the housing and blow it out with air pressure. Re-lube with light lube other than WD-40 which gets sticky with age. Worked like a charm on my choke and hand throttle.
| | | | | Joined: Jul 2018 Posts: 84 'Bolter | | 'Bolter Joined: Jul 2018 Posts: 84 | I did my heater control cable. I clamped a rubber tube over the cable sleeve. I then filled the rubber hose with oil and used the blow gun on my airline to force the oil down. Gravity would probably have worked. On the first try with the air gun the pipe came off and blew out the oil down my shirt. Wife Not pleased. | | | | | Joined: Aug 2016 Posts: 121 'Bolter | | 'Bolter Joined: Aug 2016 Posts: 121 | A few years ago I bought new Choke and Throttle cables for my 1947 3100 with Rochester one barrel. Everything new including knobs on dash. A friend did the installation and while there are no issues with them working it seems like they are too long under the hood as they are both routed around the carb before hook-up. Question: Shouldn't each cable be just long enough to reach from the firewall to the respective hook-up point on the carb? Can these cables be shorten and still work properly? Last, does anybody have or know of a picture that would show these cables from firewall to carb and how they are routed? Thanks. | | | | | Joined: Apr 2005 Posts: 7,440 Bolter | | Bolter Joined: Apr 2005 Posts: 7,440 | Yes they can be shortened. Be very careful with the hacksaw as you cut the coiled sheath. Then trim the inside wire after you get it installed in the final location.ðŸ›
| | | | | Joined: Mar 2016 Posts: 225 'Bolter | | 'Bolter Joined: Mar 2016 Posts: 225 | But, be sure and pull the center wire (or cable as some call it) out of the housing first, grab it by the knob and remove the whole center wire. Cut the housing to length, feed the center wire back through, make sure the knob is pushed all the way in, and then cut the center wire to length.
I had to trim both my choke and throttle cable, about 15"-16" to get rid of the excess.
Mike
1951 3100 5 window
| | | | | Joined: May 2007 Posts: 1,718 Moderator: 60-66 Trucks; North Eastern Bolters | | Moderator: 60-66 Trucks; North Eastern Bolters Joined: May 2007 Posts: 1,718 | Maybe a silly question, but can the cable come all the way out without disturbing the installed sheathing. In that if all is installed and i wanted to oil the wire can i just detach from carb and pull from cab? All goes back without a worry? | | | | | Joined: Feb 2004 Posts: 29,771 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,771 | If there's a kink in the end of the push-pull wire at the carburetor end caused by clamping the setscrew down on it, it's likely that the wire won't slide in and out smoothly. Either carefully straighten out the kink, or cut the wire back a bit to eliminate the kinked spot. Jerry
| | | | | Joined: Apr 2011 Posts: 523 Shop Shark | | Shop Shark Joined: Apr 2011 Posts: 523 | I have found that for stranded cables, it helps to melt the end with a torch. Bob
BobS46
| | | | | Joined: May 2007 Posts: 1,718 Moderator: 60-66 Trucks; North Eastern Bolters | | Moderator: 60-66 Trucks; North Eastern Bolters Joined: May 2007 Posts: 1,718 | | | | | | Joined: Aug 2016 Posts: 121 'Bolter | | 'Bolter Joined: Aug 2016 Posts: 121 | Where can I locate a picture showing the Choke and Throttle cables from firewall to carb as they were when they left the factory? Thanks. | | | | | Joined: Jun 2008 Posts: 1,644 'Bolter | | 'Bolter Joined: Jun 2008 Posts: 1,644 | Update.........
With both the choke and throttle cables in place, I applied more than a few drops of “Three-in-One household oil” directly to the spiral outer surfaces of the cables. Just as I suspected, the thin oil penetrated through to the solid inner wire and the cables now slide smooth as silk! Quick fix to an annoying problem, and I didn’t have to remove or disassemble the cables to do it.
