3 members (walter74, Hotrod Lincoln, Gdads51), 62 guests, and 0 robots.
Topics128,078
Posts1,055,935
Members48,430
#1274987 08/04/2018 9:21 AM
I have a 265 sbc with Rochester 2 jet.To get the truck to start I have to pump the gas pedal about 10 times to get it to fire up.What could it be fuel pump or carb or somthing else.Thanks in advance.
V
V Offline
Is the choke fully closed when the engine is cold?
How often do you start it?
Whats the condition of the plugs?
Last tuneup?
H Online: Content
What are the results of a volume/pressure/vacuum test of the fuel pump? Remember the old Sun test equipment slogan- - - -"We test, not guess!"
Possible worn out accelerator pump in the carburetor. Dirty/clogged carburetor. Float sticking closed.
Rick
1939 Chevrolet Stake Truck
