1 members (homer52),
66
Mod | | | Forums66 Topics128,072 Posts1,055,906 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2017 Posts: 76 'Bolter | | 'Bolter Joined: Aug 2017 Posts: 76 | I have a 265 sbc with Rochester 2 jet.To get the truck to start I have to pump the gas pedal about 10 times to get it to fire up.What could it be fuel pump or carb or somthing else.Thanks in advance. | | | | | Joined: Aug 2012 Posts: 1,214 Shop Shark | | Shop Shark Joined: Aug 2012 Posts: 1,214 | Is the choke fully closed when the engine is cold? How often do you start it? Whats the condition of the plugs? Last tuneup? | | | | | Joined: Feb 2004 Posts: 29,777 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,777 | What are the results of a volume/pressure/vacuum test of the fuel pump? Remember the old Sun test equipment slogan- - - -"We test, not guess!" Jerry
| | | | | Joined: Feb 2011 Posts: 583 'Bolter | | 'Bolter Joined: Feb 2011 Posts: 583 | Possible worn out accelerator pump in the carburetor. Dirty/clogged carburetor. Float sticking closed.
Rick
1939 Chevrolet Stake Truck
