| | | Forums66 Topics128,072 Posts1,055,907 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2007 Posts: 53 Shop Shark | | Shop Shark Joined: Jun 2007 Posts: 53 | I can find the outside door skins in the various catalogs, but no mention of the inner skin, I want to open up the door and do some sound proofing and insulating, and the access is very limited. Mike Bourg | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | there are no inner parts made, just the outer/lower - a trick: note on the hinge side of the doors there's a couple 'embossed' depressed areas - cut out the biggest, easy to fab a replacement, and you can use screws to make it a removeable 'hatch', no one will ever notice
Bill | | | | | Joined: Mar 2007 Posts: 30 Apprentice | | Apprentice Joined: Mar 2007 Posts: 30 | Are you talking about this [img] http://www.brotherstrucks.com/images/IDB9H00B.jpg[/img] If so I done this repair and I like the panel. I don't car for the outter skin though, I ended up making my own. The outter skin seemed thin to me. | | | | | Joined: Jun 2007 Posts: 53 Shop Shark | | Shop Shark Joined: Jun 2007 Posts: 53 | roughly that is what i was after, but not a door bottom, just the inside skin, and after looking at this real hard, I believe i will end up making as you have done, they just wont have the scalloped effect that the original has, but they will get covered with carpet anyway. thanks to all Mike Bourg | | |
