6 members (carbking, HandyAndy, dt235sd, Otto Skorzeny, UtahYork, klhansen), 49 guests, and 1 robot.
Topics128,053
Posts1,055,777
#1274539 08/01/2018 1:03 AM
Good evening guys!!
I have a question about the serial number on my 1952 Chevy 6400 Loadmaster (Please). So, on the serial number plate inside the drivers door, it shows a GVWR of 16,000 pounds. What I am getting questioned about is the Serial number.
Per the plate, the serial number is KEA135170. I sold this truck to a guy and he is saying that it is totally wrong and it may be but it sure looks like it was originally stamped by GM because the numbers are in a perfect line and not sloppy. The K even looks like it has some kind of circle around it.
Are the bigger truck serial numbers a little different than a 1/2 ton pickup? The serial # on my 54 pick up is H54S048707.
Please advise and Thank You in advance!!
1953 3100 with 1957 235, T5 and 12 bolt 373 rear
Guys,
I found a Stovebolt link that says the number is legitimate.
http://1954advance-design.com/Stovebolt-engine/casting-numbers.html
Thanks!!
That is from my website, Kevin,
Here is the original source of that information, from the original 1952 Chevrolet Salesman Truck Data Book.
KEA = 1952 Chevrolet 6000 series truck assembled in Flint, Michigan
Thanks Tim!
