4 members (DadsFirstPickup, BC59, Lightholder's Dad, Otto Skorzeny), 127 guests, and 2 robots.
Topics128,135
Posts1,056,422
Members48,441
I'll be welding in some new floorpans on Dad's 51 3100. Which size wire should I use on the mig- .023 or .030? Would it make a difference as far as finish or anything? Thanks.
.023 is the way to go for body work. less weld deposit to grind. If your fabricating a trailer the .030 is better it will carry more Amps and deposit a weld faster
Thanks! I was kind of figuring the same, but thought I might be told that it was all a matter of feed speed and amperage. I appreciate it...
My first experience doing floor pans wasn't so neat and I blew holes thru the metal. frown Oh,the agony of grinding and filling. :mad: Hope yours goes much smoother. cool
Drew
I use .023 on thin like body pannels but floor pans and structure i use .035.But i punch holes around the out side of the pans so i can spot weld and grind them off. you can't even tell after you are done.
1955 GMC Big Window
1957 Chevy 1.5-Ton
1959 Chevy Short Fleetside
Plus lots more ...I LOVE THESE TRUCKS!!!
