1 members (baldeagle),
70
Mod | | | Forums66 Topics128,037 Posts1,055,466 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2004 Posts: 313 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 313 | Good evening guys!!
I have a question about the serial number on my 1952 Chevy 6400 Loadmaster (Please). So, on the serial number plate inside the drivers door, it shows a GVWR of 16,000 pounds. What I am getting questioned about is the Serial number.
Per the plate, the serial number is KEA135170. I sold this truck to a guy and he is saying that it is totally wrong and it may be but it sure looks like it was originally stamped by GM because the numbers are in a perfect line and not sloppy. The K even looks like it has some kind of circle around it.
Are the bigger truck serial numbers a little different than a 1/2 ton pickup? The serial # on my 54 pick up is H54S048707.
Please advise and Thank You in advance!!
1953 3100 with 1957 235, T5 and 12 bolt 373 rear
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | That is from my website, Kevin, Here is the original source of that information, from the original 1952 Chevrolet Salesman Truck Data Book. KEA = 1952 Chevrolet 6000 series truck assembled in Flint, Michigan | | | | | Joined: Mar 2004 Posts: 313 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 313 |
