0 members (), 108 guests, and 0 robots.
Topics128,115
Posts1,056,292
Members48,439
#1273895 07/26/2018 8:32 PM
I have rusty brake fluid leaking out of my front wheel cyls. What would cause this , everything was new (lines,master cyl. and wheel cyls.) 10 years ago, and it's stored inside. Can I get by with a hone and new rubber?
Crusing in the Passing Lane
Since you live in the rust belt, 10 yoars is plenty of time for rust to start all over. You could try new rubber, hone, replacing all fluid!
Ed
7
7 Offline
Brake fluid is hydroscopic-it absorbs moisture from the atmosphere regardless if it's under cover. Sounds like at least time to rebuild all cylinders and flush the system.
Might be a good time to have the master and wheel cylinders sleeved in SS or brass so you won't have to do this again in your lifetime.
We should all flush our brake fluid every two years or so to get the water out.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Insomniac
Insomniac
Use DOT-5 fluid. It's not hydroscopic.
Gord 🇨🇦
1954 1/2 ton 235 4 speed
