8 members (mick53, Lostbuthaulinass, carbking, Southerntruck, Otto Skorzeny, 1955 1 Series, 52Carl, cmayna), 154 guests, and 0 robots.
Topics128,114
Posts1,056,282
Members48,439
#1273730 07/25/2018 12:08 PM
I saw a 1957 6500 truck for sale. It has a 283 and overdrive transmission. Does anyone know if these came with the R-11 overdrive?
1958 Chevy Grumman Olson step van
Being such a large truck it's not likely a BW overdrive unit like used on the small trucks and cars.
Could be a Clark 5 speed overdrive, or possibly a Spicer. Or could be an auxiliary transmission with overdrive after the usual 4 or 5 speed, If so likely a Spicer 3 speed, possibly 4.
•1952 Chevrolet 3800 pickup
---All pictures---
Crusing in the Passing Lane
It could be a NP-540 series, 4 shift rails, Al top cover, or Clark, 3 shift rails, Ci topcover with rounded corners.
Both of these trans.' have high(OD) gear to the right and forward, direct is right and back.
Both of these trans.' have a big gap in ratios where they got the OD position from(3rd), which is really awkward with a load unless a two speed rear end is there.
Ed
Good info. Thanks gents.
IF you have a OD transmission, it's not a factory transmission. Chevrolet never put a OD trans in a 1957 big truck (only the 3100 & 3200 had a optional OD transmission). The 6000 Series Trucks were standard with the SM-420 4-speed with an optional New Process 5-speed (direct drive). This 5-speed has a shifting pattern that looks like this;
1...2...4...R
....3...5
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
