| | | Forums66 Topics128,109 Posts1,056,271 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2012 Posts: 307 'Bolter | | 'Bolter Joined: Oct 2012 Posts: 307 | I saw a 1957 6500 truck for sale. It has a 283 and overdrive transmission. Does anyone know if these came with the R-11 overdrive?
1958 Chevy Grumman Olson step van
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Being such a large truck it's not likely a BW overdrive unit like used on the small trucks and cars.
Could be a Clark 5 speed overdrive, or possibly a Spicer. Or could be an auxiliary transmission with overdrive after the usual 4 or 5 speed, If so likely a Spicer 3 speed, possibly 4. | | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | It could be a NP-540 series, 4 shift rails, Al top cover, or Clark, 3 shift rails, Ci topcover with rounded corners.
Both of these trans.' have high(OD) gear to the right and forward, direct is right and back.
Both of these trans.' have a big gap in ratios where they got the OD position from(3rd), which is really awkward with a load unless a two speed rear end is there.
Ed
| | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | IF you have a OD transmission, it's not a factory transmission. Chevrolet never put a OD trans in a 1957 big truck (only the 3100 & 3200 had a optional OD transmission). The 6000 Series Trucks were standard with the SM-420 4-speed with an optional New Process 5-speed (direct drive). This 5-speed has a shifting pattern that looks like this; 1...2...4...R ....3...5 Mike B  | | |
