1 members (CuzzFuzz),
83
Mod | | | Forums66 Topics128,135 Posts1,056,423 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 29,817 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,817 | Drop me a PM- - - -I'll reply with my phone number. This has gone on far too long, and I think you're mere minutes away from getting that thing running! Jerry
| | | | | Joined: May 2005 Posts: 215 Shop Shark | | Shop Shark Joined: May 2005 Posts: 215 | We’re almost there I think Got better response to trying to start by switching spark plug wires and making sure seated all the way in the distributor cap Now it’s almost coughing Also got back fire when swapping the wires around so we have fuel and spark Next will be check the valves again and new spark plugs Thanks Jerry
| | | | | Joined: May 2005 Posts: 215 Shop Shark | | Shop Shark Joined: May 2005 Posts: 215 | Finally got it started After replacing the distributor (Langdons) and new plugs started the first time around Now to initially warm and re-torque the head bolts I assume one bolt at a time; any sequence? | | | | | Joined: Jan 2013 Posts: 1,518 'Bolter | | 'Bolter Joined: Jan 2013 Posts: 1,518 | Head bolts torque, start on the center of the head and then alternate sides working from the center 1953 Chevrolet 3100261 cu inch, sm420, 3.55 rear, torque tube still,omaha orange, still 6 volt, RPO green glass, side carrier spare, all done In the DITY GalleryVideo of the 261 running1964 GMC 1000305 Big Block V6, sm420, the next cab off restoration
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | | | | | | Joined: Nov 2011 Posts: 1,611 'Bolter | | 'Bolter Joined: Nov 2011 Posts: 1,611 | Finally got it started After replacing the distributor (Langdons) and new plugs started the first time around Now to initially warm and re-torque the head bolts I assume one bolt at a time; any sequence? Great to hear you got the engine running. People ask many questions, but few report back results...thanks for doing so as it helps others (including myself) learn. Did you install an original style points type distributor? | | | | | Joined: May 2005 Posts: 215 Shop Shark | | Shop Shark Joined: May 2005 Posts: 215 | Hello all Another set back.... So got it running good enough to warm the engine After that, was going through the sequence of retightening the head bolts and the oil supply bolt snapped Luckily I was able to take the broken end from the block, through the head with a screwdriver Does anyone have a bolt to spare or source to buy? Chevs of the 40’s has bolts, but they do not have the hole, nor the stepped shoulder like the oems Not sure if this is necessary bolt because it did not have the slit at the top and it’s a 1956 block with a 848 head; it looks like someone modified themselves. Before the head rebuild I had oil starvation problem to the rockers so I have a line from the oil sender port in the block to the head
| | | | | Joined: Dec 2017 Posts: 1,652 'Bolter | | 'Bolter Joined: Dec 2017 Posts: 1,652 | Depends on the year of the head and block. There was more to it then just the bolt, there was a plug also. In 59, gm changed the oiling system slightly from the 55-58 motors. Service replacement blocks for 55-58 motors eventually changed over to 59-62. So if you had a bad block on a 55-58, the service replacement was the 59-62 type. In order to use the later block with the earlier head and rockers, you installed a tapered plug and the drilled bolt. Was not needed if replacing a late block with a late block, and using the later head.
So you want to see what year block and head you have on your hands there.
Mike
| | | | | Joined: May 2005 Posts: 215 Shop Shark | | Shop Shark Joined: May 2005 Posts: 215 | Drag six C 11 8 C 11 8 = March 11 1958
k216 K 21 6 = November 21 1956 | | | | | Joined: Feb 2004 Posts: 29,817 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,817 | Any head bolt the right length can be converted to an oiler bolt. Just grind a thin slot into the threads about 1/16" wide and slightly deeper than the minor diameter of the thread root. The other method is to drill a small hole dead center into the threaded area of the bolt and drill a hole sideways to intersect with it. You don't need a very big hole- - - -slightly over 1/16" should be plenty, and if it's done correctly the strength of the bolt isn't compromised. Jerry
| | | | | Joined: Aug 2012 Posts: 1,214 Shop Shark | | Shop Shark Joined: Aug 2012 Posts: 1,214 | To add on to HRM's suggestion, the link should be helpful: Good Info | | | | | Joined: Dec 2017 Posts: 1,652 'Bolter | | 'Bolter Joined: Dec 2017 Posts: 1,652 | So with a 58 and 56 head and block combination, the bolt and plug is not used (and was never installed from the factory, btw.) That may be part of the oiling issue if your motor did have the bolt and plug installed. Here is the rub as I see it. If your motor had the bolt, does it also have the plug installed in the block? I don't know that it matters at this point any how as you have provided the rockers with oil from a secondary source so you likely only need a standard head bolt and I myself would not drill it (given that you don't need it).
Mike
| | | | | Joined: May 2005 Posts: 215 Shop Shark | | Shop Shark Joined: May 2005 Posts: 215 | I did not see a plug when i had the head off So to confirm, non-drilled bolt will work and i will still get oil to the rockers? It looks like that's where the oil is being supplied though Oiler | | | | | Joined: Dec 2017 Posts: 1,652 'Bolter | | 'Bolter Joined: Dec 2017 Posts: 1,652 | If your casting dates are correct, then no you do not need the drilled bolt and plug. Remember, that bolt was only used when you were replacing a 55-58 engine (short block) with a 59 and up service replacement (short block fitted block), but were still using the 55-58 head and rockers. If you were doing that, you installed the plug in the block which stopped the oil from the standard pathway to the rockers, installed the early head and rockers, and used the drilled bolt which was an alternate pathway to the rockers- with the drilled part of the bolt providing the restriction for the oil so the oil dribbled out of the early style rockers (oil groove inside the rocker arm intersecting the dribble hole, as opposed to the later 59 and up rocker arms where the groove is offset from the dribble hole) as opposed to spitting over them. These drilled bolts were not installed in any production motor whatsoever. I have an nos bolt and probably 7 or 8 nos little plugs. I keep them around for conversation sake.
Mike
| | | | | Joined: May 2005 Posts: 215 Shop Shark | | Shop Shark Joined: May 2005 Posts: 215 | Has anyone used standard grade 8 bolts to replace these? I can only find Chevs of the forties that carries these, but it's $15+ just for shipping 1-2 bolts McMaster or Fastenal has these but, they do not have stepped shoulder like the OEM's Bolt | | | | | Joined: Feb 2004 Posts: 29,817 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,817 | What length of bolt do you need? Send me a PM with your mailing address and a measurement from the bottom of the bolt head to the end of the thread. I've got a couple of junk engines and I'll be glad to send you a head bolt. Jerry
