3 members (Shaffer's1950, DannyW, Otto Skorzeny), 126 guests, and 2 robots.
Topics128,080
Posts1,056,291
Members48,441
I finally got the heater fan switch (new from Classic) wired to the fan motor. Hooked the battery up and the fan went on. Problem is that the thee way switch is in the off position. It still runs in all three positions. Wire from motor goes to one pole of switch. The other is from accessory terminal on ignition switch to the other pole of the heater fan switch. . Is the switch bad or is it wired incorrectly?
Does your switch look like this?
...click...
Yes.
Originally Posted by Snowman51
Yes.
...click...
That switch has 3 positions. Low , med, high. And off
The only problem youll have if you wire that switch the otherway is that the light will be on all the time
If it runs in off position and the other three positions you have a bad switch
Ex Hall Monitor
Ex Hall Monitor
This is where a multimeter is handy. If you have continuity from your power in lug and any of the others with the switch in the off position it's a bad switch.
Thanks guys. I’ll check it tomorrow.
So I checked the switch. DADS50, turns out I not only did I wired it backwards(light on all the time), but one wire was off the terminal. Hooked up correctly now and works like a champ. 3 speeds, with the first position after the off being the fastest. Is it suppose to haul a## on high?
Good job, DADS50
Nice report Snowman51
I have a recirculating heater in a breezy (no door/window seals) 1954 truck that kept me so warm that I had to take off my coat (in 4 degree F at 55 mph).
You can hope that yours is up to that performance.
There were 2 Chevrolet-brand truck heaters: the recirculating heater and a more-expensive temperature-controlled Air-Flow/Fresh-Air heater.
Post a photo or two and we can tell you what you have.
Glad you got it worked out
With that particular switch I only use low and med,
I like that the intensity of the light changes with the speed
Yup-recirculating. My 1951 “breezy” is like yours. Can’t wait for winter to try it out. My next job is replace the fuel pump.
