0 members (), 106 guests, and 0 robots.
Topics128,101
Posts1,056,181
Members48,436
Working on replacing some rotted metal where the kickpanel meets the floorboard. I am replacing the factory rubber mat with the factory style rubber mat. Does anyone have any photos or measurements of approximately how far up the sides the mat goes, if at all? Just want to know at what point the joint will be covered by floor covering.
The mat doesn't go up the side at all. You can get kick panel trim pieces to cover any ugly welds. I just painted.
NHluvstruck...
1951 3100 5-window,.sold, regretted
https://stonefacegarage.wixsite.com/mysite
51 Chevy Restoration Page
The floor mat fits tight to the kick panel. However, the combination of the thickness of the floor mat and the padding under it will hide about 3/8" of the bottom of the kick panel.
Thanks guys! It isn't the side of the kickpanel as much as it is the floor pan. I just wanted to have a visual of where i could expect the floor mat to cover to. I'm planning to dress the welds and make it look right, but it also helps to know if something doesn't go right, that area will/will not be covered by mat.
