5 members (Swami29, Gdads51, joe apple, 2 invisible), 88 guests, and 2 robots.
Topics128,116
Posts1,056,637
Members48,450
My son has a 1946 2 ton and his battery appears to be on it's way out.
Waiting to see if the battery takes a charge then I want to load test the
battery.
I have checked regular auto batteries and have a load tester, It is a Sun BST 5.
So the question is do you load test a Gel Cell battery different?
Thank you, Jeffrey
What brand battery?
6v or 12v (not that it matters regarding your question).
If you have an Optima battery, there is a special/required charging procedure for a dead Optimal "gel" wetted-mat battery.
Sealed Absorbed Glass Mat (AGM)
My son has the battery fully charged. The charger's green indicator light is on.
Jefffrey
Edit to add the charger is made to recharge gel batteries.
