| | | Forums66 Topics128,104 Posts1,056,201 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2008 Posts: 544 Shop Shark | | Shop Shark Joined: Nov 2008 Posts: 544 | Working on replacing some rotted metal where the kickpanel meets the floorboard. I am replacing the factory rubber mat with the factory style rubber mat. Does anyone have any photos or measurements of approximately how far up the sides the mat goes, if at all? Just want to know at what point the joint will be covered by floor covering. | | | | | Joined: Jul 2013 Posts: 160 'Bolter | | 'Bolter Joined: Jul 2013 Posts: 160 | The mat doesn't go up the side at all. You can get kick panel trim pieces to cover any ugly welds. I just painted. | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | | | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | | | | | | Joined: Mar 2010 Posts: 10,280 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,280 | The floor mat fits tight to the kick panel. However, the combination of the thickness of the floor mat and the padding under it will hide about 3/8" of the bottom of the kick panel.
| | | | | Joined: Nov 2008 Posts: 544 Shop Shark | | Shop Shark Joined: Nov 2008 Posts: 544 | Thanks guys! It isn't the side of the kickpanel as much as it is the floor pan. I just wanted to have a visual of where i could expect the floor mat to cover to. I'm planning to dress the welds and make it look right, but it also helps to know if something doesn't go right, that area will/will not be covered by mat. | | |
