2 members (Nick in Manitou, 1 invisible),
350
Mod | | | Forums66 Topics128,162 Posts1,057,042 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2010 Posts: 127 Shop Shark | | Shop Shark Joined: Aug 2010 Posts: 127 | I wish I had a good story for this one, but I don't... I dropped a piston yesterday, it landed on the engine stand and took a chip out of the bottom of the piston skirt (the long side). The cylinders are in great shape, the pistons were in fine shape too, this was supposed to be a quick clean and new gaskets and back together. So, can I still use the piston or is it toast? | | | | | Joined: Apr 2005 Posts: 7,441 Bolter | | Bolter Joined: Apr 2005 Posts: 7,441 | Photos of the damage would be nice.  My gut says no, get a new one.
| | | | | Joined: Feb 2004 Posts: 29,871 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,871 | What engine are you working on, and where is the chip? If it's anywhere on the skirt at right angles to the wrist pin, that's a thrust-bearing area. If so, make it an expensive paperweight! Jerry
| | | | | Joined: Dec 2003 Posts: 1,061 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 1,061 | There always seems to be an odd lot of pistons on e-bay. Maybe you can find a single piston reasonably priced
1946 1-ton Panel 1952 1-ton Comml. W/Grain Body | | | | | Joined: Feb 2004 Posts: 29,871 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,871 | Rock Auto sells single pistons- - - -we had to buy two of them for John's 261 when we built that one. Jerry
| | | | | Joined: Aug 2010 Posts: 127 Shop Shark | | Shop Shark Joined: Aug 2010 Posts: 127 | Sorry, total lack of info there... the engine is a 216, its out of a 1941 1.5 ton truck. I put a picture of it in my photobucket, just click the link with my name to see the pic. | | | | | Joined: Aug 2010 Posts: 127 Shop Shark | | Shop Shark Joined: Aug 2010 Posts: 127 | It looks like ebay only has pistons for the 37-40 216's, rock auto doesn't sell them, Jim Carter only has over sized sets, so I'd have to rebore my engine. This could be one hell of an expensive lesson. | | | | | Joined: Feb 2004 Posts: 29,871 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,871 | What's the bore size, standard or oversize? I've got a bunch of cast iron 216 pistons sitting around that I'm not likely to use on any of the engines I rebuild. I bore 216's 60 over and use aluminum 235 pistons in them. It keeps Babbit rods from wearing out in a hurry due to the lighter weight of the pistons.
While you're in there, consider installing a set of spring steel "piston skirt expanders". They really quiet the engine down by reducing piston slap, especially after a cylinder gets honed and ends up slightly oversize. There are several sets on Ebay right now, at around $20.00 a set. Jerry
| | | | | Joined: Feb 2004 Posts: 29,871 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,871 | There are some new old stock standard bore 216 pistons on Ebay right now- - - -selling singly with a starting bid of $35.00 apiece. Jerry
| | | | | Joined: Aug 2010 Posts: 127 Shop Shark | | Shop Shark Joined: Aug 2010 Posts: 127 | Thanks for finding that Jerry! Are the pistons for a 53 the same as my 41? If I remember correctly 41 is different than 37-40, but I don't know about after 41. Thanks again! | | | | | Joined: Mar 2016 Posts: 226 'Bolter | | 'Bolter Joined: Mar 2016 Posts: 226 | Hotrod A....check your PM.
Mike
1951 3100 5 window
| | | | | Joined: Feb 2004 Posts: 29,871 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,871 | If your pistons are standard bore flat tops, the ones on Ebay will be a drop-in fit. Jerry
